Question about D-Link Express EtherNetwork DI-604 Router
Ares ultra doesn't connect router is a d-link wbr1310 looking forward to some type of help
    Scholar:
  • 31 Answers
Please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Posted on Mar 14, 2009
The router shows it is connected, but I do not have internet acess
Hello;
First connect via Ethernet. Then
  • Click START'RUN and then type CMD
  • At the black window with the prompt(cursor) type ipconfig and search "default gateway"
  • Type the gateway address in the browser ej: 192.168.0.1
This is for enter the web administration of the router. I don't know your revision. But I will get you the Hardware Version: A1 Firmware Version: 1.04
  • Aim for Status as the picture above
On the WAN section is the actual Internet. WAN = Wide Area Network. Your computer is actually on the LAN = Local Area Network. The Computer looks the address on the router, then the router go to the WAN for the information. But this is transparent to the user. If the WAN is in cero on the addresses, you have to check the installation. when the installation are correct power cycle the modem and the router and try again. Always connected via Ethernet cable. Hope to help! coquibiz.jpg
Nov 26, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Tip
How do I find my routers IP Address, in Windows XP
1: Ensure that the computer you are using is connected to the router, by an Ethernet cable.
2: Click Start and select Run.
3: In the Run command box, type cmd and click OK.
4: In the Command Prompt, type ipconfig and press Enter.
5: Locate the Ethernet adapter Local Area Connection. Under this header find the Default Gateway. The address displayed here, should be the address of the router (192.168.0.1 by default).
on Mar 09, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can't configure wbr1310. no screen comes up 192.168.0.1
try 192.168.1.1 or open the command prompt, type in ipconfig and look for the default gateway. once you got the numbers, type it in internet explorer.
Sep 08, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Unable to connect ipodtouch
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 22, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do I secure this router?
First go to the address bar and type in the default ip address of this router: IP address is 192.168.0.1 Then open this link for instructions on programming the wireless security settings. http://www.voiproblem.com/emulators/DLink/wbr1310/support_internet.html
Oct 28, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I my dlink is working but i can not log in to dlink network to change setting
I would first try to connect thru a wired connection to the router if you are using wireless. then in your browser type 192.168.0.1. You might have to unplug and reset your router if you can't connect.
Oct 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have the WBR1310 D-Link wireless router. I
I would try one or both of the following:
1. Update any drivers or software for the D-Link router.
2. Update the firmware of the router (see page 38 of the user manual for instructions to do this). -- you can download the manual at http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310 if you dont have it.
Hope this helps.
Oct 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Letting Ultra VNC go through a Dlink router to connect to a serve
You may have to define the VNC service under services then port forward that service on port 5900 to internal 5900.
Of if it has a Virtual Server option just forward port 5900 to 5900 and send it to the LAN IP Address of the computer you want to use.
If you need instuctions let me know and i'll post,
ta, HPC
Feb 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Port forwarding
portforward.com/english/routers/port_forwarding/Dlink/WBR-1310/WBR-1310index.htm
Nov 28, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link Express EtherNetwork DI-604 Router Logo
236 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
