Question about Pasquini Livia 90 Espresso Machine
Livia 90 Lights come on then off, hums but not pumping
My Livia has been on the shelf for about 8 months. Worked great then. Now I go to use it, The lights will come on for a second, then go out, THen machine begins to hum. But no pump activity.
    President:
  • 1,618 Answers
It is possible that the pump is blocked or damaged, remove top and side panels and check lines going to and from pump, you can run the machine without the panels and you will be able to see if the water is moving to the pump or if the pump is vibrating.
Posted on May 14, 2009
Pump has started making gurgling sound
You may have an air lock try using machine on and off 5seconds each time sow that you give the pump time to regain the water.
If not try and inject water your self from the rare instead of water tank some time when you get air lock it is removed alone by just simply leave it over night after you had tryed the water pump because the air lock is removed alone slowly.
Feb 24, 2016 | Pasquini Livia 90 Semi Automatic Espresso...
My machine is actually a Bezzera Bz99 which seems to be exactly the same internally as Pasquini Livia 90. The problem is Machine turns on and both lights go on. After a few seconds, relay clicks and green...
I know this is an old post but I have the same issue and need to replace the transformer. How to get in touch with Tyler di Giovanni? Can't seem to find contact info ;(
Oct 27, 2013 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
I own a vintage Pasquini Livietta cappuccino maker that has recently stopped working. It still produces steam and I can hear the pump working, but no coffee is produced. The machine was working fine before...
Remove the shower screen and make sure it is clear, then remove the screws on the top panel, If after checking screen problem still occurs, find the tube that leads to the head and make sure it is not blocked.
Jan 31, 2010 | Pasquini Livia 90 Espresso Machine
Where can I get an owners manual for a Pasquinin, Livia 90?
I found a writeup about this machine below. It has a great deal of information that may help you out:
http://ix.cs.uoregon.edu/~michal/espresso/livia-90.html
Additionally, you can contact the maker directly, and they should be able to supply you with a printed owner's manual. Their web page is below:
http://www.pasquini.com/
Sep 28, 2009 | Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Leaking from the grouphead
The fix to this problem is replacing the group head replacement done every 8 months to a year. The part number is #90907 $4.50+shipping and I have this in stock.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Feb 18, 2009 | Pasquini Livia 90 Espresso Machine
All 3 lights on Livia lighting up with hot water use
Is this a Livia 90 semi or auto ?? It sounds as if you are talking about an auto. The autos have had a history of the cpu controller board going out. Probably going to have to take it in for service for proper diagnostic repair. Parts are not cheap and with no warranty- you don't want to start throwing parts at it to get it working right.
Jan 27, 2008 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
197 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
