Question about Eljer 212-1088-00 White Dumount Double Basin Cast Iron Kitchen Sink from th
How to remove a cast iron kitchen sink installed
How to remove a Delta cast iron kitchen sink installed on a coriander counter top?
  • 150 Answers
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Len
Posted on Feb 22, 2009
    President:
  • 2,976 Answers
Disconnect everything from underneath. Remove the clips that hold the sink down. Run a thin putty knife around the top outer edge of the sink. Is is ready to push upward.
What do I need to clean my sink with to keep the shine?
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
Mar 08, 2011 | Jacuzzi Kitchen Cast Iron Black Finish...
My Jacuzzi kitchen sink was installed in 2004, I noticed pitting & stains within one year & reported it to the installer. He took photos & never got back to me. The sink is easily stained,...
New sink,its 2011 and its done its service to its country.Nice Kohler cast iron drop in is the way to go.Most peoples issues with sinks are abrasive cleaners ,even softscrub,it takes the finish off of all types of plumbing fixtures,cast iron- fiberglass- stainless etc.I tell people not to use anything you wouldn't use on your car finish Elkay makes some nice stainless sinks.Top of the line,let jacuzzi stick to whirlpools
Jan 26, 2011 | Jacuzzi Kitchen Iron White Finish...
Will under mounted sink take the weight of garburator?
The sink should be physically mounted with clips if it is not cast iron, otherwise a cradle made of wood is usually the route I go.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
May 15, 2010 | Jacuzzi Kitchen Iron Black Finish...
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
Apr 18, 2009 | Eljer 212-1088-00 White Dumount Double...
Is an acrylic sink durable and stainproof?
Acrylic sinks can stain too. I would go with a cast iron sink if you don't want to worry about stains. Acrylic sinks tend to scratch if your not careful.
Mar 13, 2009 | International Thermocast Corp Thermocast...
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
Installation of an iron cast kitchen sink
please ask for live chat from me and I will walk you step by step thank you
Feb 24, 2009 | Jcp Home Collection Marble-Top Vanity w/...
Jacuzzi undermount sink
Your sink is clearly made to be undermounted. No trim ring available. With all of the choices now available for sinks and faucets I would recommend that the jacuzzi sink be removed and that you select a new sink and faucet set to your liking. good luck.
Jan 21, 2009 | Jacuzzi Kitchen Iron Black Finish...
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Eljer 212-1088-00 White Dumount Double Basin Cast Iron Kitchen Sink from th Logo
1,117 people viewed this question
Top Eljer Plumbing Experts
Donni Steen
Tom Chichester
Are you an Eljer Plumbing Expert? Answer questions, earn points and help others
