Question about Philips 60PP9401 60" Rear Projection Television
Everything is shadowed and the picture itself seems to be a bit darker. Tried running Intellisense, came back with '4'... I have my owners manual and there is nothing about Intellisense, not how to use it, what it does or means, nothing. I had a repairman (from a household name major appliance company) come to look at it, what a waste of money. The first thing out of his mouth was 'I don't have any literature on this...' what does that mean? He doesn't have a book? I sincerely hope you can help. thanks in advance.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.everything is shadowed - 2c07611.png/>2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set thaeverything is shadowed - 578ba6c.jpg fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
I have a Magnavox 50ML8105D/17 the picture is getting darker
You need a new bulb replacement. The owner manual will even instruct you how to change the bulb.
Oct 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Menu (SCREEN) #4 Adjusting projection is gone
you have a convergence problem and this can only be serviced by a tech with the know how to service the rca projections sets as there are many alignments in this set and some are manual driven but mosrt are on screen driven. You need the know how to get into the service mode. Sorry my friend but my recomendations would be to send this set out for service.
Jun 08, 2006 | RCA P56812BL 56" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
