Question about Imperial Kitchen Ranges
Where is the pilot light for imperial range oven
I have an Imperial 6 burner range, with a convection oven. I need to light the pilot light for the oven, but I am not sure where to look. I have the metal cover flipped open which exposes the on/off oven switch for when you open the door. But I still don't see where to light the pilot. Can you help?
    Novelist:
  • 125 Answers
Hello. I will try to guide you, in the area that you described, there should be a pilot safety valve, and usually they have a red button you depress in order to get gas to the pilot. The pilot is usually beyond the safety, if you follow the pipe from the safety, into the burner area, that will lead you to the pilot. Put your match,lighter of choice there, while holding in the red button. wait approx. 30 to 60 seconds, then release. If all is well, your pilot is now lit, however you still may need some attention, like cleaning the pilot and orifice. If not, you will need possibly a thermocouple for the pilot/safety, or a safety. Either of those I would suggest you call a local service company, check your phone book under "restaurant equipment repair"
Hope that helps, and thank you.
Posted on Feb 22, 2009
Stick the torch or whatever way back on the LEFT hole. You will see the pilot go on. Do not let go of the red button (which you are holding the whole time) for 60 seconds after it's lit.
Posted on Aug 18, 2011
Its a electrical pilot... doesn't have the usual pilot light..
Posted on Sep 23, 2014
  • lee062988
    lee062988 Sep 23, 2014
    its a convection oven
I have an Imperial gas 6 burner range. All my pots are getting coated in soot. The appliance is 11 years old and this is a new problem.
Old jets are in need of cleaning or replacing because they are not allowing the fuel to be burned completely! If their orifices are too large, too much gas comes through and there is not enough air to use the gas completely.
Jan 22, 2013 | Imperial Commercial Cooking Equipment...
HOW DO YOU LIGHT THE PILOT FOR THE OVEN? OVEN I
Remove the oven floor & the access panel below the door,inside of lower access panel their will a gas valve with a red button on it, push red button,light pilot burner connected to main oven burner,hold red button for 15-20 seconds,release red button and pilot should be on.reinstall panels
If you release red button and pilot goes out the thermocoupler needs to be replaced
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Imperial IR-6-C Elite Gas Kitchen Range
Range has electric igntion and it will not heat. the ignition and burner will cycle on intermittently then it would shut off. it would do this for 3 times. its a imperial convection oven IHR-4-C model. was...
It sounds like your ignition module is unable to prove flame for some reason. This could be caused by poor positioning of the flame sensor, a bad ground to the burner or to the ignition module. If the flame is not engulfing the flame sensor on the ignitor, the module will attempt to light three times and then lock out. Poor air flow or too much air flow through the burner compartment can blow the flame away from the ignitor as well. Hope this help
May 17, 2011 | Imperial Commercial Cooking Equipment...
How do you turn off the oven pilot?
you have to turn off the main gas, or you can turn the pilot adjust screw, all the way off..clockwise,
i would not do the 2nd one
Dec 19, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
How do turn on the pilot to the oven? and how do I know its calibrated correctly? I have an LP version
On this unit the pilot lights it's self when the oven needs heat as for checking the oven you can put a temp probe over the exhaust and it should read around 20'c less that it is set to
Oct 04, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
How do you light the pilot for the flat top section of our Imperial 6 top stove?
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
On my Imperial gas oven the pilot light ignites but doesn't start the burner
Do you push a red button to light the pilot ? Does the pilot stay on after you hold the button for 30 seconds ? Need more information. Could be the safety... could be the thermocouple....?
Tom
Aug 10, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
Oven gas will not flow with pilot lit
There are basically two types of ranges to deal with:
those with sealed top burners, which are pretty much the standard today, and the conventional, 'non-sealed' ones.
While they operate in much the same way, their conversion is usually different. There are still a few ranges that use adjustable sealed burner orifices, but most are 'fixed' and must be individually replaced to convert each burner from one fuel to another.
(An orifice is simply a small brass fitting with a specifically sized hole very accurately drilled through it, and, if adjustable, has a provision to change the size of this hole by turning closed a threaded portion).
Either way, basically what you're doing when going from natural gas to LP is changing to a smaller orifice to allow for the higher pressure supplied by the 'bottled' gas (The available energy in each ft of gas is different too, but for our purpose here that's not important). Natural gas supplies typically run around a pressure of 5.5 inches water column, while LP runs at twice that pressure, averaging around 11 inches.
The orifice through which the gas travels to the burner must be smaller to accommodate this difference.
Adjustable orifices are simply 'snugged' down, clockwise, with a 1/2 inch open-end wrench, to convert them. Nearly all oven burners use these too - more about that in a minute.
Fixed orifices are replaced, and the good news is: the LP parts are usually included with the new range. On some brands (GE being one), the unused set is attached to a storage point on the stove, and this is a great idea. This way, they can't get lost, and if you ever want to convert back, there they are!
The not-so-good news: these little top burner orifices very often require a metric wrench to remove & install. And some can't be changed without a very slender wrench or nut driver.
Aug 08, 2009 | Imperial Kitchen Ranges
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Kitchen Ranges Logo
3,284 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
johnny3h
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
