Question about Maytag Neptune MAH5500B Front Load Washer
Door will not lock
Neptune MAH5500B error code FL - broken door lock - it will not lock door. What part do I need to buy to fix this problem?
  • michellemcco Mar 08, 2009
    the door is simply JKL:LKJ! i am so sick of it not closing properly and having to adjust the door every time it closes to get it to latch! Is there any compensation from MAYTAG for this problem, the advice above is great but will not work for me. if you have a website or email address for this faulty part where MAYTAG ASSUMES THE RESPONSIBILITY THEY BY ALL RIGHT SHOULD FOR THIS FAULTY PART-- would someone please submit it?
    thanks!
    President:
  • Maytag Master
  • 2,651 Answers
Faulty Latch ,, i would order and replace the latch assy, you acess the latch by removingthe 4 screws in the dispensor assy, the n remove the door, andthe 2 screws opposit teh door hinge. then the front "u shaped" panel will come off and then just 2 5/16" screws on either side will release the main top assembly allowing you to tip it backwards and gaining acess to the latch assy
Posted on Feb 22, 2009
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
I s a Maytag Neptune washer error code "FL" something I can reset myself?
Error on the door lock or the door switch, try and use a switch cleaner, remove and reset the lock or check the harness to the switch
click this link: Door lock
Jan 20, 2013 | Maytag Neptune MAH5500B Front Load Washer
Not locking
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Door is locked and has a code of FL on panel
FL Failed to lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
I'm getting error code FL when trying to start my washer. It will start to fill with water and then error. Please help! It seems like the door is locked.
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 23, 2011 | Maytag Neptune MAH5500B Front Load Washer
Says FL and won't run
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
3. Check the wire harness connections to the door switch/lock unit and Main control board.
If the wire harness is ok, replace the door lock mech.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door lock mechanism
I had this problem also with my Maytag Neptune TL. The door lock would click muptiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure eaither that or sandpaper will do. After that it went through the whole cylce without stopping or displaying the "FL" code.......hope this helps
Jun 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
"FL" light
The "FL" error code indicates that the door is not locking. The buzzing sound you hear is most likely the door lock trying to lock the door. It may only be a matter of aligning the door so that it locks properly. Otherwise, you may have a faulty door lock that needs to be replaced.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
941 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
