Question about RCA RCU300WBL Remote Control
Need code for RCU300 US IB ReV C to be used for a Toshiba TV
I need to get some code for my TV remote with serial #RCU3000RB Rev C
I need to progranm it for my Phillips TV
Posted on Apr 02, 2009
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I have just purchased an LG32lcd 450 tv, I cannot get the handset on Sky to work as they do not have a code to do this as the tv is new to the market, can you please help with this
OK, as you already discovered there is no specific code for your remote. You can try the generic codes for LG which I've listed below. Your TV may use the same flash patterns as some other older LG TVs so these codes might work.
Try these codes but if they don't work it's unlikely your remote will work with your TV - you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due - which will hopefully contain a specific code/flash pattern for your TV - but I've not been able to confirm this yet.
Nov 23, 2010 | LG Televison & Video
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Mar 20, 2008 | Televison & Video
RCA RCU300WBL Remote Control Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
