Question about Vehicle Parts & Accessories
Car alarm won't reset after disconnecting car battery
Was working OK until I disconnected the battery. When I went to reconnect the battery the alarm activated and I can't reset. The ignition lights come on but the car won't start.
Its a mongoose alarm (not a factory alarm) with key entry and there's a switch (like the ones that operate the light in a fridge) under the bonnet.
I've disconnected one of the wires to the siren (does the siren need to be connected for the alarm to be reset?)
  • Rayrod11 Mar 06, 2009
    Can't reset armed alarm, the alarm keeps going on and self reset but doesn't let the ignition work or turn on the car
  • 95 Answers
You should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Posted on Feb 22, 2009
  • darnash2000 Mar 22, 2011
    With the Code Alarm system, we unhooked the positive side of the battery for 5 minutes and then rehooked it. The alarm with the remote now works fully again.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2004 mg zr had to disconnect battery also replace the key fob case. When i reconnected the battery the alarm went off. Fob won't turn it off Can i use the key only to turn alarm and immobiliser off
Try disconnecting the battery and leaving it overnight. Unlock the car, insert the ignition key and switch on - then reconnect the battery.
That sometimes works. If it doesn't you will need some experienced advice and specialist help. Rover/MG usually needed to be opened by whatever locked the car to avoid the alarm sounding. If the key was used to lock it, then using the key to unlock should be ok though I seem to remember the alarm will sound after a short time if the key isn't put into the ignition and switched on fairly quickly.
Aug 11, 2017 | MG Cars & Trucks
Need security code error for 2006 Ford Falcon BF turbo please as car won't start at all. Please help?
O.K. Jeanne lets start here did you disconnect the battery or did it go dead yes/no if yes when cables were reconnected ///or battery jumped the alarm went off putting the car into theft mode and that's why the no start condition flashing red alarm light=== you have to disconnect the battery again and when you reconnect it the alarm will sound when it does you have to press the remote control button///key fob to stop the alarm and you will be able to start the car please post back if there's something else and please the most important thing to remember is that any one here who wants to help you is not standing there with you so everything must be told be very specific about what's happened ///happening O.K.
Mar 21, 2015 | Ford Falcon Cars & Trucks
2000 Jetta GLS 5 speed. I bought a new car, I went for a ride in it, drove and idled great. Went to start it later and alarm went off, it turned off after a minute but now the car wont start, battery...
This is a wild guess, but disconnect the positive terminal from your battery. Touch the cable (that went to the positive) to the negative, to drain out any capacitor in the system that is holding charge. I think you have to short it that way for about 10 seconds. Reconnect cable to positive and start car.
That will reset your computer and should reset the alarm as well.
Aug 03, 2013 | Cars & Trucks
1997 jeep grand cherokee won't start after alarm went off
I just had the same prblem. Reconnect your alarm first of all. You need to use your key bob "remote" to deactivate the alarm before starting. It is a feature "good one" i might add that should someone try to steal it the jeep will not start until u deactivate it w theke bob.
Jan 20, 2013 | 1997 Jeep Grand Cherokee
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
What to do if the alarm keeps going off and the car won't start? Toyota carolla 2010
First of all disconnect the battery, wait 5-10 minutes, then reconnect it to reset the alarm system. If this doesn't work you have to take it to dealership, could be a faulty alarm ecu.
Jul 11, 2011 | 2010 Toyota Corolla
2003 Nissan Altima car alarm won't stop going off. Went off every 30 minutes last night until I disconnected the car battery. Reconnected the battery this morning and still went off. Don't have a...
hand it over to a mechanic or Nissan. If you recently had an M.O.T and it went of quickly then ask for a refund, even better, ask him to take a look at the car again
Jul 02, 2011 | 2003 Nissan Altima
Won't start after cleaning battery terminals
Sounds like you have an aftermarket alarm with starter disable. By disconnecting the battery the alarm reset and the defualt setting is usually to set the alarm automatically (active arming). You have three options..
A. If you have the key fob that went with the alarm you can disarm the alarm.
B. If no key fob is available you can disconnect the battery again, turn the ignition key to the on position and reconnect the battery. This usually doesn't allow the alarm to set and allows the car to start.
C. Remove the aftermarket alarm system. This is usually the long term fix i recommend if the fob isn't available. Option B should get you going though.
May 09, 2009 | 1993 Toyota Corolla
Vehicle Parts & Accessories Logo
4,085 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
