Question about Toshiba Satellite A205-S4707 Notebook
On my Toshiba Satellite a205-s4707 dvd player not working
On my Toshiba Satellite a205-s4707 all of the suddent the dvd player does not work. I have tried all types of cd and dvd. I get the message The specified drive cannot be located. Please help. Thanks in advance, Carole
    President:
  • 2,653 Answers
Allright this one can be tricky so we need to isolate the problem between software and hardware.
First, get into the bios and see it's being detected.
If not then turn off the computer and unscrew the drive from the laptop, MAJORITY of laptops only need to have one screw unscrewed to release the drive. If yours doesn't then you'll have to do a little more work, let's just assume you have the majority for now.
Next, pull the drive out, feel free to give the back connector a quick puff of air, now carefully place the drive back into the laptop so that it's nice and tight.
Check to see if that solves your problem.
If not we'll try something else.
Posted on Feb 22, 2009
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
Jun 06, 2014 | Toshiba Satellite A205-S4707
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite A205-S4707 Boot time is to long need help
you may need a fresh install of the OS, maybe upgrade the ram to 2-3gb, or the worst case factory discs for series model laptop.
Oct 19, 2012 | Toshiba Satellite A205-S4707 Notebook
Hello all! I have Toshiba Satellite a205 s4707, with Windows 7. It has latest Toshiba drivers, bios is after update, but I can't run camera. I tried everything that I found on the internet but non...
Go to toshiba.com and download the correct drivers plus the updates. Any other problems use the phone number on the web site for technical assistance.
Toshiba have got it right.
Jan 17, 2011 | Toshiba Satellite A205-S4707 Notebook
My staellite A205-S4707 gets a charge, powers on but will not stay on for more than 30 seconds. any thoughts here?
A couple of thoughts,
Is this the case while connected to the charger? If not try starting it while still connected to the charger. If it runs OK, your battery may have died.
If it still doesn't run, it may be a over-heating problem. Check underneath, see if all the vents are clear and free of dust.
Mar 23, 2010 | Toshiba Satellite A205-S4707 Notebook
Toshiba satellite A205 DVD player partially Inop
The disk drive could be going bad, or the lens may be dirty.
Try getting a dvd lens cleaning kit if you don't already have one, and run that. Make sure to read all the instructions that come with the cleaning kit.
ex - http://www.walmart.com/catalog/product.do?product_id=9123830
May 31, 2009 | Toshiba Satellite A205-S4707 Notebook
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite A205-S4707 ethernet connection issues
Try this:
Open a command prompt. If it has been opened before you should see it on your start menu. If so , RIGHT click on it and select Run as Administrator.
If it is not directly on your start menu , go to Start > All Programs > Accessories > command prompt and do the same.
In the command prompt , type "ipconfg /release"
without the quotes of course.
Then type in "ipconfig /renew"
You should have an IP Address now.
Type "ping www.google.com"
you should get something like this:
Pinging www.l.google.com [64.233.169.104] with 32 bytes of data:
Reply from 64.233.169.104: bytes=32 time=15ms TTL=247
Reply from 64.233.169.104: bytes=32 time=14ms TTL=247
Ping statistics for 64.233.169.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 15ms, Average = 14ms
You should have 0% loss. If not , something else is going on.
Otherwise , try your browser now and you should be able to connect.
Mar 03, 2009 | Toshiba Satellite A205-S4707 Notebook
Toshiba A205-S4707 Display issues
This happens when the Mother board, which is the place were all the cables meet inside the computer might not be working correctly. This process needs to be handle by a professional to change the Mother Board.
Thank You!
Jul 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4707 Notebook Logo
183 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
