Question about Dell Dimension 3100 PC Desktop
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Had 512 MB memory and upgraded with two 1-Gig Dell memory cards, but Windows fails to fully boot; Gives error message Running with BIOS A04.
  • 447 Answers
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Posted on Feb 22, 2009
    President:
  • 2,653 Answers
Easy one. Pop that old memory back in and visit Dell's support site. You'll have to do a BIOS upgrade so that the motherboard will be able to recognise the memory.
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Memory
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
Ethernet driver for windows 7
There does not seem to be a valid Windows 7 network driver:
http://ftp.dell.com/Pages/Drivers/dimension-3100.html#Network
You can try the driver for XP to see if that will work, otherwise you may need to buy a new NIC card.
Oct 14, 2013 | Dell Dimension 3100 PC Desktop
Dell 3100 windows wont load after memory upgrade
Re-seat your memory modules and check to make sure you didn't knock any power or ide, sata cables loose or forgot to plug them back in when you were done working on the ram.
Also, make sure your RAM meets these requirements:
Type - 400- and 533-MHz DDR2 unbuffered SDRAM
Memory capacities per slot - 256 MB, 512 MB, or 1 GB non-ECC
Maximum total memory - 2 GB
If it still doesn't work then test each RAM module separately with memtest86+ to find out if one is bad.
Jun 18, 2012 | Dell Dimension 3100 PC Desktop
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I just upgraded memory from 512 to 2 gigs, but the computer only shows 1 gig. why?
The other 1 gig is not properly installed oropushed in all the way
Oct 02, 2009 | Acer Computers & Internet
Dell 3100 suspected overheat
Try using Old RAM. If old RAM works well and new show the same behaviour, then new RAM timmings are not matching with the motherboard timmings. (ehteshamhusain@gmail.com)
Jul 23, 2009 | Dell Dimension 3100 PC Desktop
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Memory upgrade problem
That does not sound like a problem with a memory upgrade. try to unistall McAfee and reinstall. The memory change may have threw McAfee off. Make sure that the ram is also in the right bus. Buses are color coded and the 2 ram stick have to go into the same bus. this can cause problems
Jan 15, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
625 people viewed this question
Alun Cox
