Question about Averatec 6200 Notebook
Avertatec laptop won't boot up and customer service number is disconnected. I guess that they are a broke d.ck fly by night wannabe computer company. Do not by Averatec products. YOU WILL HAVE NO COMPANY SUPPPORT WHEN YOU HAVE PROBLEMS CAUSE THEY ARE OUT OF BUSINESS!!!!!!!!!!!!!!!
  • RescueTechLA
    RescueTechLA May 11, 2010
    What's it doing or not doing?
    I wish they were still in business they're laptops were really well designed.
Back firing and sputtering after oil change and spark plug replacement, oil was overfill, replace the air filter air lines gasket. This is a Harley Night train 2006, 88ci, fuel injected
Hi Lorabell777, take it back to the dealer and demand satisfaction politely and you want it fixed for free since you already paid big bucks for the practice repair. If they give you any static ask the store manager for the Motor Company's customer service phone number so you can ask them why your dealer won;t waranty their work in a timely manner. Good luck and have nice day.
Jan 26, 2012 | 2006 Harley Davidson FXSTBI Night Train
I don't know the model number of the lock. It was installed in 1993.The latch broke. I got a new latch but cannot get it to work. Either it won't go or the handle slips. It does not have a key....
Start on this web page to identify your lock:
http://consumer.schlage.com/Products/Pages/category-landing.aspx?category=Electronic+Security
Then go to this page for links to the proper instruction and programming manuals and videos for your lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
If you're still having a problem or need parts, here is the contact information for Schlage Customer Service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Hope this helps!
Jun 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
I am trying to put a new message on the after hours message bank, but it won t erase the old message. How do I erase the old message
Here's the simple answer. When you go to record a new message, it will play the old message and offer to let you record a new one. Your system consists of three key pieces, the phone, the KSU (key service unit) and the VOICE MAIL SYSTEM. Guess where the "message bank" is?
In our systems, we use Custom Service menus to play the greetings, but there can also be COMPANY greetings in front of the CS menu. In a TVA system, we use low numbers like 1 for day and 2 for night, only because it's a GUI to set up the menus. In a TVS system, we use 30 for day and 60 for night so the sub-menus have slots.
Try looking for the installation instructions to see if you can find the menu flowchart. In any case, the old message will play before you're given the option of changing it and you must confirm the change with a "2".
Carl
Mar 21, 2011 | Panasonic KX-T7630 Corded Phone
Computer was charging all night. Someone tripped over cord and pulled cord out of computer. Computer won't turn on. Computer did not fall.
There's two way on how we can turn our laptop on:
1. With the battery
2. Without the battery using the AC adapter or Power cord
Try the above options to isolate your issue.
- If number 2 option works then that means that there's something wrong with your battery.
Solution:
1. You can buy a generic laptop battery which is less expensive than the original battery. (Generic Laptop battery means different brand like the one made in china that fits your laptop.)
2. Buy a refurbished battery (Second hand battery)
3. Go back to the store where you bought or call their customer service if your still under warranty (Battery warranty for most laptop company is 90 days )
4. Buy a new one (Recommended if your out of warranty).
We're done with the lighter side of the issue our bigger problem is if your laptop wont turn on using the 2 option above.
This means that there's something wrong with the Laptop,
Solution:
1. If your still under warranty you can go back to the store where you bought for repair or call their customer service
2. If your out of warranty then you need to look for local tech.
Jan 29, 2011 | Acer Aspire One PC Notebook
I need to install a cam stage 2 on my night rod special 2008 model ? the harley davidson company where im living (united arab emirates, DUBAI )already charged me more then 3000& still did not manage...
Hi Osbh, take it back to the dealer and demand satisfaction politely and you want it fixed for free since you already paid big bucks for the practice repair. If they give you any static ask the store manager for the Motor Company's customer service phone number so you can ask them why your dealer won;t waranty their work in a timely manner. Good luck and have nice day.
Aug 26, 2010 | 2008 Harley Davidson VRSCDX Night Rod...
It just stops when you turn off and on agains sometimes the windows moving thing< lol because I do not know what it is called just stops also. Please help a 67 year old computer wannabe! Thank you...
Hello.
It's great that you are a 67 year old computer wannabe ... I didn't grow up in the computer age, either.
Anyway, I think you are saying that your system freezes ???
If so ... either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
And ... if I'm off the mark as far as your problem is concerned, please let me know.
Hope this helps.
Jan 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hampton Bay Cessna Glass Globe Replacement
I don't think King of Fans manufactured your fan, BUT their FAQ says...
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Mar 08, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Averatec 6200 Notebook Logo
78 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
