Question about Whirlpool Inglis IP4400 Washer
Rust in the holes in the drum of an Inglis washing
I have an Inglis machine - its not that old and I have already had a drum replaced because of the rust in the holes of the drum. When you do your laundry you end up with rust on anything that is light in colour. Would not have thought I will need to get it replaced in less than a year later.
    Sergeant:
    Champion:
  • 214 Answers
If you live in a rural area and have a well or bad water you may need a water softner installed.Fill your washer and add clr let run for a bit but do not let it drain stop washer then leave sit over night that should take most of the rust out of your tub.
Posted on May 07, 2009
Rust in drain holes
Could be the drum rusting or high mineral content in your water supply, try a mixture of CLR "Calcium Lime and Rust remover to dissolve the rust thats in the wash tub in a small wash cycle, then monitor if it comes back.
Dec 10, 2012 | Washing Machines
What's your problemI have an inglis royal 100 model 1a 86600 The white clothes come out with brown stains on them. It is old but seems to work well. Could it be the front gasket around the drum? I
there either is a rust mark on the tub or under the agitator oil could be leaking out or metal is rotting where the tranny shaft comes up under the agitator but like you said it's old and parts are starting to rust out and decay
Oct 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washing machine has chipped around the holes in the tub and has rusted. It leave rust marks on my white clothes. Is there any way to repair the tub? The washer is about 5 years old but I am a...
You used to be able to get a brush on product that was used to fix chips in baths and appliances.. I can't remember what it was called, Check around some appliance shops perhaps they might remember?
Feb 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
If I forget and leave clothes in the washer overnight or for a day or 2 will it rust the drum?
That should not rust the drum unless there are holes in the unit it may cause water to exit the drim and cause rust on other parts.
Dec 07, 2009 | Kenmore Washing Machines
Rusty holes on drum
Hi
If you find a good plasticizing epoxy it should work great for this most plastic epoxies can withstand temperatures up to 500 degrees F. I dont see the hot water supply feeding the machine getting any warmer than this. Another option would be to find someone with a plastic fusion and filler welder and just weld the hole shut with a base material.
OR
Follow this easy steps...
Unplug the dryer from the electrical socket to avoid accidental electrocution.
Sand or scrub the rust spots using steel wool or sandpaper. Rust creates pits and these pits need to be smooth, like the rest of the drum areas, to prevent the rust from getting worse and to allow touch-up paint to stick.
Clean the entire inside of the drum to remove all the dust left from sanding/scrubbing. Mild soap and water will work well. Use old rags that can be thrown away.
Let the drum dry completely. You can run your dryer on the fluff dry cycle for a few minutes to dry the drum faster. If you use a heat cycle, the drum will become too hot and you will have to wait while it cools
Apply an appliance paint (see Resources) in the color that most closely matches your drum. Use the applicator that comes with the paint to dab the paint on the rust spots. You may need to add more than one coat, but make sure that you are letting the first coat dry before adding more to avoid drip marks. Allow all coats of paint to dry thoroughly before using the dryer.
Thanks for contacting fixya.com
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WHY IS THERE RUST IN MY WASH MACHINE DRUM
Hi
Thanks for using FixYa. Take out the clothes immediately after the washer stops spinning. Also clean the tub with a rust remover. This issue occurs due to bad drum bearing and it may be grease rather than rust. Although the tub is metal with porcelain coating and it wears around the edge of the holes first, leaving metal without porcelain. On spinning the centrifugal force pushes the clothes against the basket and some water sneaks into the holes. Due to this you may see the rust on clothes. If still the issue persists, then the tub is required to be replaced to resolve the issue. Please do rate the solution and revert for further assistance. Thanks Rylee
Sep 18, 2009 | Kenmore 24032\24036 Top Load Washer
New inglis washer expells water when fills
seems like no one wants to send you any love Richard. Well fear not, if you haven't figured this out yet, I'll do what I can. It seems to me that you have the drain hose lower than the top of the wash basket or a hole in that hose. If the drain hose is too low, the water will run out of the machine due to low center of gravity. Ideally, 6" above the level of the tub is sufficient. If there is a hole in that hose, replacement is pretty straight forward.
Jul 18, 2009 | Whirlpool Inglis IP4400 Washer
I want to replace the water pump from my Inglis Washer
yes you can force it off it's bad anyway so go for it and when you do get it off clean the rust off the shaft before you put the new one on. You are doing great.
Apr 02, 2009 | Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Rust in tub
Unfortunatly, this happens every now and agian. Sometimes a button or something will pop a piece out of the porcelain, then you have rust. The problem is, the companies will tell you (which you have probably heard a hundred times already) that if its out of warranty, its not their problem. Other than that. Unfortunatly, out of the few we have delt with, most of our customers either try to find a lawyer or replace the drum. Havent heard anyone being successful in getting satisfaction from a lawyer. Sorry, believe you me I know how you feel. The old saying "They Dont Build Them Like They Used To" really does work now-a-days. Good Luck to you. Jim
Sep 07, 2007 | Whirlpool LSR7333 Top Load Washer
Whirlpool Inglis IP4400 Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
