Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Truck wont start makes cliking nosie
Iv wired every thing up right it a motor swap but all it does is make a cliking nosie
Sounds like your starter is bad, you could take it off and to the auto parts store and they can test it. My chevy did the same thing, all it is is a bad solenoid most times, which is located on the starter
Posted on Feb 23, 2009
  • danny8486 Feb 23, 2009
    or it could also be a dead battery, I would take them both and get it checked, if it is a new motor i doubt it is locked up and won't spin, but you can always try to turn the crankshaft with a wrench on the harmonic balancer pulley just to be sure it spins.
MY CAR WONT START THE BATTERY IS FULY CHARGED
What make model an year vehicle ? Starter relay could be bad starter motor could be bad ? You have to test the electrical circuit ! Find A wiring diagram for the starting circuit of your vehicle at http://www.bbbind.com/free_tsb.html . Do you own a DVOM - digital volt ohm meter or a test light . Depending on the year of your vehicle it may or may not have a relay . Go on youtube an check out videos on testing relays , basic automotive electrical trouble shooting , voltage drop testing , how to read a wiring diagram . Then armed with this knowledge test the starting circuit .
Jun 18, 2016 | Cars & Trucks
Has spark but wont start
Fuel . Make sure the carburetor isn't plugged up at the fuel metering orifice. A plugged air filter will do it too.
Jun 17, 2015 | Heavy Machinery
Got fire got gas wont start
it takes only 3 things. to run.
1: good motor, compression test. (we do that after any head swap)
2: good spark and spark timed right. you need a book to follow there.
3: good fueling, not flooding and not starving.
if #1 and 2 are good, then you can use test fuel to see if motor runs
on test fuel (cut fuel pump for test)
in that order, and there are simple tests for each.
Apr 17, 2013 | 1995 Geo Metro
Car makes cliking nosie wen turnin right
either a bad engine to chassis earth cable or a low battery or the starter motor is on its last knockings
Oct 31, 2010 | Hyundai Accent Cars & Trucks
It making a load buzzing nosie hafe way threw the cycles and it stops and my clothes are not rasied out and soaked still from not being spinned i dint put no more then usually iv had this probmle before...
F30 Dispenser system error . Bad or jammed motor, broken wire.
Remove the dispenser and put it in the dishwasher for a cycle. That will clean it up.
Take the bottom panel off and dump the pump filter.5cfa9a5.jpg0084008.jpg4d0f9ba.jpg
I have a service manual HERE with more info
Oct 19, 2010 | Kenmore HE2 Plus Front Load Washer
Making a nosie on driver side but when i distconte
is it a very fast wizzing noise?
if so the seloniod on the starter motor has gone! give it a tap with a hammer if you can get to it or put the car in 2nd gear and take the hand brake off, make sure the keys are not in the ignition and push the car forward it until you feel the engine turn, it wont start but should free off the starter motor.
Jan 15, 2010 | 1999 Dodge Durango
Truck wont start with new motor
first thing is check your neutral safety switch
Dec 18, 2009 | 1985 Chevrolet K3500
Changed autobox an now my 2002 grand cherokee wont start!!!
first, close and lock all the doors. lock the drivers door using the key, then unlock it and try to start the car. Also, make sure you have 12v at the battery or obviously the car will not start.
Jun 05, 2009 | 2002 Jeep Grand Cherokee
It just wont work!!!!
What cars do you have? year/make/model
Aug 19, 2007 | Kenwood KDC-7009
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
113 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
