Question about Dell Dimension 2400 PC Desktop
Trying to log on to Dimension 2400, but won't come on power is going thru. AB light in back is yellow
  • saubert Feb 22, 2009
    I do not hear any beeps, but can feel the hard drive on. A&B lights remains green. When I tuned it on it goes off and with I turn in it comes back on again. The fan is on and power is going to everything. Change hard drive, but that was not the problem.
  • Mike Davidson
    Mike Davidson May 11, 2010
    I need a bit more information.Do you hear any Post Beep or any beeps as it boots up?
    Can you hear or feel the Hard Drive spool up?
    Please let me know.
    Thanks!
    Scholar:
  • 164 Answers
Okay, That helps,
What did you do to the computer *prior* to this issue?
You need to look at a few things. Remove all memory sticks except one.
Try to boot. If it does work, then you have a bad memory stick.
Add another stick and so on.
if you have a Video card in a slot, remove card and relocate to another slot (IF RAM does not fix).
Make sure CPU is fully seated as well.
Can you boot to safe mode using F8 ?
lets get the first 2 things done first tho.
Thanks for the fast reply!!!
Posted on Feb 22, 2009
Dell front panel power light abcd lights yellow
Does the monitor go out completely, no power? Or just lose a signal? Check ALL cables, AC and Monitor cables. Could be a Graphics adapter issue or Monitor , try another monitor.Your computer has a few miles on it , right? You could buy a PCI Graphics card if the monitor is OK.
Jan 01, 2013 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
Put in new memory in a dell 2400 now front
make sure all cables are properly seated inside the case. just the d light being yellow and no other means some other failure occured,
Feb 20, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 that has had a power surge
Um, unless you are happy soldering VERY finely and under pressure then go for it, but to be honest, you can pick one up for £30-£50 that will have everything you need and more!
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
Unable to reboot system after upgrades
1. Check your RAM speed
2. Install the old RAm and see if the problem persists
Jun 24, 2009 | Dell Dimension 2400 PC Desktop
Yellow light on dell dimension 2400 and it won't work
HI, this is signaling an issue that is concerning the power unit(power supply). this can also be an issue with the mother board as well. you can confirm the actual issue by, inspecting the cooling fan that is on the power unit. if the power unit fan is not running when you push the power button to power up the PC, replace the power supply. if the fan is running, replace the mother board.
Jun 21, 2009 | Dell Dimension 2400 PC Desktop
Dimension 2400 can not power on
If you have no power by pressing the front power button and you have verified that the black connector coming from the power switch on the front is connected properly to the motherboard, then make sure that both connectors from the power supply are connected properly, the main connector and the p4 connector. Reseat both of the connectors to be sure.
If you still have no power and still have the light coming up on the motherboard then I think the motherboard may be bad cause that means something is shorting out the motherboard and not allowing power to go thru it properly.
Mar 08, 2009 | Dell Dimension 2400 Power Supply ** FREE...
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
44 people viewed this question
Alun Cox
