Question about Sony DAV-S400 System
Dvd carousel will not open
My daughter jammed a dvd in and now the unit does not play and will not open for me to get it out. Help!
    Scholar:
  • 93 Answers
The best solution would be to unplug the unit and attempt to remove the top cover or lid and remove the disc from the platter, many units will unscrew from the sides and back panel.
Posted on Feb 22, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Here, this link should help http://diagramas.diagramasde.com/audio/HCD-GX90D%20RV800D%20sm.pdf
Posted on May 03, 2015
Emerson EWC19T3 tray will not open
Maybe it can---an expert needs to take unit apart to see if just freeing the one jammed in the door can be cleared --it is 50-50 chance.
Apr 16, 2012 | Televison & Video
Technika tv/dvd the dvd is only in black and white and wont play the discs
you can try using a DVD cleaner disk on your unit, try several times to make cretin it is clean then try your DVD`s again, if the unit was stored in a damp area this may be a problem, DVD players can be finicky due to this, there may also be a manufacturing defect in the unit that made it fail prematurely.
Jan 09, 2012 | Televison & Video
I have a Yamaha carousel d.v.d. player and the carousel is jammed. i cannot load or eject. how can I unjam?.
If you are technically inclined, you may be able to fix this. Any discs not in the carousel correctly must be CAREFULLY removed - NO FORCE. Inspect the carousel for damage. Look at the disc pick fingers and see if they are broken. Remove all discs and run the unit to see if it goes 'home', disc one. With the discs in, you take the chance it cannot run right and damages more discs.
I use the clear cover disc from DVD stacks as fake discs. I can see everything the machine does through the clear plastic.
Mar 29, 2010 | Audio Players & Recorders
My Harman Kardon FL 8550 will not play, the display shows error and the carousel seems stuck. I already cleaned the lens.
Couple possibilities.
Disc jammed inside, take cover off and inspect.
Worn belts, belts are old and worn and it can't move the carousel or open, stripped gears will also have the same effect.
Or electronic problem, not worth repairing.
Nov 27, 2009 | Harman Kardon FL8550 CD Player
DVD player will not open
Hi, I think the DVD disc was not positioned properly (since yo udid mention that the disc did not play) adn that it has jammed the tray. Please avoid furtherusing the unit as this may damage the eject gear mechanism. Only recommendation is to bring the unit for service and they can physically rmeove the jammed disc.
Aug 09, 2008 | Bose Lifestyle 18 System
I have a toshiba dvd-cd player model sd3815n. The last time we used it the tray would only open about one inch and the carosel would not play the cd or dvd
There could be something stuck in there if it isn't opening all the way and the carousel isn't playing. If you can open the top and see whats going on.
Jul 10, 2008 | Toshiba Televison & Video
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
DVD tray will not eject
go to the any depanator and help to zero(.)settyng your dvd
Nov 28, 2006 | Emerson SB350 13 in. TV/DVD Combo
DV-C302D - Carousel not opening
First. Unplug the DVD for 30 seconds, plug back in and turn set on, sometimes it helps. Second, some CDs may have some rough spots around the inner and outer edges. If your DVD has it, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Jan 19, 2006 | Pioneer DV-C302D DVD Player
Sony DAV-S400 System Logo
142 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
