Question about Northgate G5NSS 15 in. Flat Panel LCD Monitor
I don't know how to get my moniter speakers to work.
I went to Control Panel and scrolled down on the Sound and Audio Devices's Advanced options and I clicked Monitor Stereo Speakers and I turned all the volumes up, but the monitor speakers still won't work. This is my first time trying to get them to work, but I've had this monitor for a while.
  • Anonymous Apr 11, 2009
    there are no ports for cables ,the speakers are in the monitor
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Do you have an audio cable (2.5 mm jack/jacks) connecting the monitors speakers to your computers sound card?
  • 202 Answers
You need to connect an audio cable from the sound card to the monitor? Once that is connected you should be able to control the sound normally.
Good luck and please let me know how it works out for you!
Posted on Feb 22, 2009
My audio cannot work,no sounds
Desktop or Laptop ?? and operating system ??
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps. Laptop If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 05, 2013 | Microsoft XP Computers & Internet
Speakers don't work
desktop or laptop computer ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
hope this helps W7
Sep 19, 2012 | Audio Players & Recorders
The board don't any sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
Oct 16, 2011 | Computers & Internet
I may have disabled the hdmi audio and I don't know how to enable it again :(
here is a sound issue resolution
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 10, 2011 | LG Computers & Internet
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
also
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
I have no sound. my speakers are ok.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 14, 2011 | Computers & Internet
I had reformat my PC .. because it wasn't working out .. i was not able to save all the drivers .. as in ALL .. when i finished reformatting my PC .. I discovered that it had no sounds at all .. My PC is...
also
hope this helps
Apr 13, 2011 | Computers & Internet
My sound went out on my computer. At first it sounded distorted. like talking through a helium balloon and then it just stopped working all together. My sound is on and everything is plugged in. And the...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 18, 2011 | ASUS Computers & Internet
My speakers work fine. I don' t know why thay keep turning. i have the internet. How do i keep my speakers on all the the
also
hope this helps
don
Feb 16, 2011 | Audio Players & Recorders
No sound
also
hope this helps
don
Feb 16, 2011 | Toshiba Satellite U305-S2804 Laptop
Northgate G5NSS 15 in. Flat Panel LCD Monitor Logo
88 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Brian Sullivan
Brian Sullivan
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
