Dell Motherboard
Problem for Dell (E210882) Motherboard
Need a new motherboard
By smartlittlef on Feb 22, 2009
took my dell into best buy and they did some test and i need a new motherboard. how much are they and will you ship one. what do i need to do. thanks janice
Clarification Request
Posted by TampaNative on Feb 22, 2009
What model Dell?
Mostly, what was the problem before you took it to Best Buy?
What tests did Best Buy do?
What were the results of those tests, if they told you?
It may not be feasible to replace the motherboard compared to upgrading the CPU, once the age of your CPU and the complete cost of upgrading the Motherboard are fully considered. So let us know what you have.
Solution #1
posted on Feb 22, 2009
Not Rated)
warrants3
Rank: Wiz
Rating: 84%, 34 votes
Janice, the cost of a mother board can vary starting at around $75 up to as much as $300. Dell tends to be proprietary with regard to the hardware installed in their machines. Regardless of that, when replacing your motherboard you have to make sure it is compatible to the CPU, RAM, and other hardware installed in your machine. If you like the dell and have had good service from it, have them give you an estimate on cost of repair. You may find that you can buy a newer machine that is faster and more capable for less money. One thing you need to know is that regardless of brand, they all use the same parts to put a home computer together and those parts are produced by one of two (maybe 3) companies depending on which component is being discussed.
Was this helpful?
Yes
No
Solution #2
Not Rated)
preachw996
Rank: Guru  Dell Expert
Rating: 86%, 748 votes
On all but their newer XPS line Dell uses Dell specific motherboards. The only way to get one is to contact Dell and see what they will charge you for one. You can find all the info at www.dell.com
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
dell rev.aoo aa a85538-702 cant power up need terminal diagram
Answer
my optiplex gx240 suddenly wont hold bios settings. changed the board battery...no joy. confused!
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
