Question about Porter Cable 75182 Variable Speed Router Motor
Porter cable 7518 not working properly.
The router when turned on, goes up to full speed for about two seconds and then slows down to a very slow spin.  Its very strange.  Ive tried all the variable speeds, and tried using a plugin on a different breaker; still the same result.  any ideas? thanks.
drew
  • David Ford
    David Ford May 11, 2010
    Could be a couple things but I would think that the speed control is bad and for 102.00 I would check the bearings and brushes first to make sure it is spinning freely. If you want to access a breakdown and manual for this go to Dewaltservicenet.com and in the middle of the page type in your model number and download either one.
rowdy45176
  • 2176 Answers
SOURCE: adjusting the 5 speed router for different size bits
Go to Dewaltservicenet.com and in the middle of page at bottom it will ask if you are looking for manual, type in your model number and on the next page look at the manual for the type 3 router. Hope this helps
Posted on Jan 25, 2009
When the router is at slower speeds, I can stop the motor when pushing wood through a bit. when I back off, the motor starts up again. Is this normal or do I have a problem with the router.
Is it a variable speed? Routers only cut at high speed, wood anyway, if it is variable speed, They must think you will be cutting something soft, I don't know, But they are like a dentist's drill, when they slow down, they don't cut, Keep that thing on high and make some dust, it should not bog down, If it does, check the brushes, if it still does, it has lost it's power and is basically shot. get a new one. Hope this helps.
Feb 27, 2011 | Porter Cable 3 1/4 Hp Bb Router
Porter cable router turning off intermittently during job
Hello. Yes it could be the extension cord or the outlet your pluged into or the feed speed of the cut.Try slowing the forward feed speed.
builderdale
Jan 24, 2010 | Porter Cable 75182 Variable Speed Router...
How difficult is it to replace a fan in a 7518
it has to be pressed on and off the armature shaft, Also unless there is a retaining ring or other stop it needs to be set to a certain depth so it wont hit the housing. I would try and see if there is a repair facility that can do this work for you, the cost I would think would be minimal
Oct 30, 2009 | Porter Cable Cable 7518 Speedmatic 3 1/4...
Slows down and looses power intermettently
you need new brushes or clean out the holes they go in so they move freely
Aug 08, 2009 | Porter Cable Porter-Cable Variable Speed...
Router runs slow
I still think that it is the bearings, especially since of the squealing noise which is a symptom of the bearing seizing up and the armature shaft would get hot transferring the heat to the motor housing. Give me the model number and brand and I will find a breakdown and part numbers for you and also if you give me your general location I will try and find someone local to get the parts.
May 17, 2009 | Porter Cable 690LR Router
Adjusting the 5 speed router for different size bits
Jan 25, 2009 | Porter Cable 75182 Variable Speed Router...
Manual
check the web sit , ace tool repair.com They have free acess to these. manuals
Aug 27, 2008 | Porter Cable Tools & Hardware - Others
Porter Cable 75182 Variable Speed Router Motor Logo
130 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Ed Mac
Mike Squire
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
