Question about Whirlpool 3.2 cu. ft. Plus Washer
My washer doesn't spin after rinsing..just drains
  • 28 Answers
Check belt
Posted on Feb 22, 2009
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag MHWE450 spins fine at full speed mid-cycle, for instance between wash and rinse, but will not spin after rinse or on "drain and spin" option. There are no error codes. Seems it might be...
Hello K.W. ,
Sad to sad their is no way to reset the control and yes it sounds as if has diagnosed it spot on ...since it spins on the rinse cycle the motor can be ruled out totally as the problem since its up to the control to tell the motor what to do and when to do it so if it spins sometimes and not others it seems to be the control that's not telling it to spin at the end. One thing to check though is that the filter screen perhaps is clogged since i believe it doesn't spin at high speed until after the water has drained and if the filter on the pump is built up w/debris its not going to drain fast enough so while it may not solve it,it may solve it by checking the drain filter. This tip i wrote will show ya how to check the filter on the pump.http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If the filter is relativity clean and doesn't solve the problem the control baord would need to be replaced.
Sep 27, 2011 | Maytag MHWE450W Washer
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wife did a load of laundry. he washer filled and started to work but it would not drain spin or rinse. it will keep running the agitator if I turn the nob its self.
check for a bad door safety switch, you can locate the switch and the connection plug and unplug the switch, and add a jumper wire between the 2 connectors that lead away from the switch , spin, rinse, and drain, need this switch to work or the machine doesn't do those motions,
Jul 27, 2011 | Kenmore Washing Machines
Whirlpool 3.2 cu. ft. Plus Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
