Question about Compaq Armada E500 Notebook
No battery, power interupted while booting up. will not boot up
Had this happen before and paid to have bios reset. How do I reset bios myself?
    President:
  • 778 Answers
Unplug the power supply, remove the battery, locate and remove the BIOS battery (connected directly to the motherboard) for a few minutes and your BIOS will revert to default settings.
Posted on Feb 22, 2009
After bios update on sony vaio vgn-fe21b the laptop will not on.
You may have interupted the procedure before it was complete.
Save your bios upgrade on cd or diskette.power down your pc and remove your battery for sometime.
Then boot your pc from the cd or diskette and begin the upgrade.
good luck.
Jun 24, 2011 | Computers & Internet
Just replaced ram on optiplex 260 won't boot, placed old ram back in still won't boot
Hello:
Open the case. And try to reset BIOS by removing motherboard battery, disconnect the source power cable and press the power on button for 15 - 30 seconds. Reseat the battery, insert the RAM module and plug the power cable. Power on normally. When prompted, load BIOS defaults or simply press <F1> to resume. See what happens.
I hope this helps. Thanks
Feb 09, 2011 | Dell OptiPlex GX260 PC Desktop
Firmware update interupted, server out
If you have jumpered for BIOS recover it should be able to boot from floppy. I think you will have to install a floppy drive, boot from floppy. Jump the MB for BMC update (if ness) and flash the BIOS and BMC that way.
Jan 16, 2010 | IBM x3400 Server
Acer Aspire PC T310 boot up problem
try bios reset, all common problems occur after a major power outage or power spikes... try resetting the bios and it should work fine, if not try replacing the video card and start from there...
Jan 02, 2010 | Acer Aspire T310 PC Desktop
Will not boot ... q50. battery light flicker 3 times
This happened to me. In order to fix it, unplug the power source and take out the battery. Hold down the power button for 30 seconds. Then plug back in the power source and the battery and power up the laptop.
This is called resetting the power cycle and should fix it.
Oct 09, 2009 | Compaq Presario CQ60-220US PC Laptop
My inspiron e1505 has the numbers lock light lit all the time and the caps lock and the lighting bolt next to it flashes for a while and nothing happens. Then the computer shuts down. Help please
Try taking out the battery and booting it on AC power only, if the laptop boots let it boot up then shut it down and reinsert the battery and try boot again. If it doesn't boot up then there is a problem with the battery.
If it doesn't boot up at all post back.
Good luck.
Aug 18, 2009 | Computers & Internet
No battery, power interupted while booting up. had problem before
Download and follow
http://h20000.www2.hp.com/bc/docs/support/UCR/SupportManual/TPM_125403-007/TPM_125403-007.pdf
Copy and paste above address in your browser.
Thanks for using Fixya.
Feb 22, 2009 | Compaq Armada E500 Notebook
PC don´t boot after upgrading BIOS
Have you tried to reset the bios by removing the battery for around 10 minutes then putting it back in??? i would try this first.
If this is unsuccesful then i really suggest you have burned your bios doing the upgrade... you might be out of luck on this one
May 02, 2008 | ASUS Intel 850 Chipset P4T Motherboard
Need boot load for emachine T2484
Hi, You need to enter your CMOS/BIOS setup and set your "First Boot Device". Immediately after powering up, press the "Del" key, display will show CMOS/BIOS settings. Verify that all your hard disks are being detected/recognized by your PC. Thereafter, set your First boot device to your new HD. Save and Exit. Hope this be of some idea/help. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | E-Machines eMachines Desktop PC
Compaq Armada E500 Notebook Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
