Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Jumping Screen 61" cinemavision
I have a 61" panasonic cinemavision and the picture jumps, the color is distorted and sometimes the picture gets extremely big and doesn't even fit on the screen. Does anyone know what this could be????
  • themofoman Nov 15, 2009
    Hi Dana1983165,
    Just wondered if you were able to get your 61" Panansonic Cinemavision fixed? If so, what was the end problem?
  • 1,139 Answers
Hello dana1983165,
The problem you described is caused by poor voltage regulation in the High Voltage power supply. This can be caused by a defective fylback transformer, a defective focus block, a defective HV trippler, of the horizontal output transistor/damper diode assembly. I would first check the high voltage from the flyback to see if it was fluctuating, you can do this with a high voltage probe. The I would check the horzontal output transistor out of circuit with a transistor checker to see if it passes.
If you do not have equipment what you can do is remove the deflection/HV board and order a replacement from panasonic.
Look up Panasonic's web site and contact their technical support number and call them to find out the part number and have them order the part for you. If this fails try PTS at
I hope this helps
Posted on Feb 24, 2009
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
If see red, blue, and green spots in the picture. Is this a color wheel problem. (I recently replaced the lamp.) If it is the color wheel, can I replace the color wheel? Or is it not worth the cost?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as
Feb 23, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I have a panasonic 47 inch cinemavision for 3 years now. there is a slight blue color distorsion when viewing. What can i do. I've tried fixing it with the remote control without luck
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Apr 03, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Sep 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Jumping picture on Toshiba flat screen model 36HF732
see ur proplem is u hit up or down or previous to much and it thinks ur still pressing it if u have a bos just turn it around and hit reset beleive me its happened before
Mar 26, 2009 | Televison & Video
Dark picture
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Oct 02, 2006 | Panasonic PT-61G54 61" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
230 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
