Question about Compaq Presario 5000 PC Desktop
Cannot figure out how to hook up speakers external on my hp pc de
I was given a set ofjbl pre external speakers .i am trying to hook them up to a compac presario pc.i have one green wire from the speakers and the only green hookup in the back of my tower has both a red and a blue plugin also like advd hookup.i tried the green plugin but no sound.they do work and are turned on
  • Mike Davidson
    Mike Davidson May 11, 2010
    What type of JBL speaker?
    that will really give me a clue!
    Thanks!
    Scholar:
  • 67 Answers
Please check if you have drivers installed for your sound device and if your sound device is working fine. please try following steps, go to start--run--type devmgmt.msc--device manager window will open-- check if u see any yellow mark in front of sound devices
even if you dont see any yellow mark. please go on drivers and download page on hp website. please put your model number in there. If you need any help please let me know i can send you the link for this. download sound device drivers. most of the time HP use realtek ac97 or realtek high defination drivers. it could be different one too. if you are unable to get it from HP website you can download it from realtek.com too
last step : if other steps does't work :
go to start--run--type services.msc ---go to window audio -- if service is stopped for some reason please start it manually by pressing start
Good luck !!
Posted on Feb 23, 2009
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
I'm trying to hook up my PC to my HD-TV using an HDMI cable but am getting a loud crackling sound through the speakers!
I have had this problem with my hp as well. Its a problem with the video drivers. The best solution is to go to the hp support website and update your video drivers to the latest version. If that doesn't work you should try a new hdmi cable. And if all else fails you can configure your audio to a different channel, like the speakers on your laptop or you can hook up some external speakers as well.
Jun 16, 2011 | HP Pavilion dv6000z Notebook
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
Speakers wont work for my Hp dc5000
You will need to disable your pc speakers. If you are running Windows XP then you can do this through control panel - Sounds and audio devices. Your external speakers should be working then if you have the correct audio software for the motherboard.
Dec 31, 2008 | HP Compaq dc5000 PC Desktop
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Compaq Presario 5000 PC Desktop Logo
204 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
