Question about LG LRFD25850 French Door Refrigerator
Water tank assembly question??????? again
The new water tank assembly I am buying comes with a hose attached to it!
can I remove the hose and just connect it to the one that is already there
  • 410 Answers
I believe the water line is removable and you will be able to use the hose that is already there. it will have a collar that you depress tehn remove the hose. thanks Peyton
Posted on Feb 22, 2009
We added anti freeze into our water hold tank. There is a pink film on the bottom of the tank. How do we clean the film out of the tank?
problem is there is an RV for your system. you will need to do the following.
Drain all holding tanks, fresh water and sewage
  1. Attach garden hose to fresh water fill and fill tank.
  2. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side.
  3. Flush toilet until clear water runs into bowl.
  4. Dump tanks again.
  5. Sanitize water system. use a water sanitizer
  6. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter.
  7. When ready to use the water heater, turn by-pass valve to open position to allow water to enter and fill the hot water heater tank.
May 10, 2017 | RVs
The black hose that drains the water out has come off and draining water straight out as it fills. I cannot for the life of me figure out where it connects to. Any help would be great!
The black discharge hose (the J shaped one) is connected to the output side of the discharge pump inside the washer. It's likely the hose has come off.
  • first, unplug the washer.
  • Shut off the hot and cold water faucets to the washer.
  • Pull the washer away so you have access to the back.
  • Remove screws holding the back panel in place.
  • Remove panel.
  • Examine the hose where it attaches to the pump. Look for cracks, holes or broken ends.
  • Examine the clamp attaching the hose. Is it broken or worn?
  • Replace any of the above hoses and/or clamps if faulty with hardware comparable with your model. Re-assemble in reverse sequence of dis-assembly.
  • Attach hot/cold water lines.
  • Ensure ALL excess water has been removed before plugging washer in. Ensure ground wire is attached!
  • Plug washer in and start cycle. Examine for leaks.
Feb 01, 2016 | Washing Machines
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
Water will not spray on my Bissell Proheat 2x Carpet cleaner
proheat 9300
assuming the water will flow with the tool attachement but not to the carpet.
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 19, 2011 | Bissell 2X Proheat 9200 rug cleaner
Where can I get solid/detailed instructions for changing out the water pump on my 2001 Yukon SLE 4.8? Something that would include torque specs. and any must does and don'ts would be nice.
Escalade, Suburban, Tahoe, Yukon, Denali, DenaliXL, YukonXL 1999-2005 Water Pump - Removal & Installation 4.8L, 5.3L & 6.0L Engines
  1. Remove or disconnect the following:
    Air outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
    Fig. Exploded view of the water pump assembly-4.8L, 5.3L and 6.0L engines
To install:
NOTE DO NOT use cooling system seal tabs (or similar compounds) unless otherwise instructed. The use of cooling system seal tabs (or similar compounds) may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
  1. Install or connect the following:
    Water pump. Install the water pump bolts. Tighten the water pump bolts first pass to 11 ft. lbs. (15 Nm); tighten the bolts final pass to 22 ft. lbs. (30 Nm). Water pump drive belt pulley and bolts (if applicable). Tighten the pulley bolts first pass to 89 inch lbs. (10 Nm); tighten the bolts final pass to 18 ft. lbs. (25 Nm). Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet duct Coolant
    Air inlet and outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
To install:
    Water pump. Install the water pump bolts. Tighten the bolts to 11 ft. lbs. (15 Nm) for the first pass; then tighten to 22 ft. lbs. (30 Nm) for the final pass. Water pump drive belt pulley and bolts (if applicable). Tighten the bolts to 89 inch lbs. (10 Nm) for the first pass; then tighten to 18 ft. lbs. (25 Nm) for the final pass. Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet and outlet duct Coolant
Hope this help to solve it (remember comment and rated this).
Apr 26, 2010 | 2001 GMC Yukon
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
How to replace just the Kirby 210097 Hose End For G5 Series Vacuum Cleaner to hose. can buy replacement but can not get the broken end off
simple and rquires no tools. Fill your sink with hot water and set the end in water with attachment on it. Within a few minutes the end is soft enough to slip out.
setting the hose end in the water again will let you simply slip the hose into the new attachment with ease.
Nov 24, 2009 | Kirby G5 Bagged Upright Vacuum
How to replace a water pump on a 2003 yukon
Water Pump Replacement (4.8L, 5.3L and 6.0L Engines)
Removal Procedure
1. Drain the cooling system.
2. Loosen the air cleaner outlet duct clamps at these locations:
 Throttle body
 Mass Airflow/Intake Air Temperature (MAF/IAT) sensor
3. Remove the radiator inlet hose clip from the outlet duct.
4. Remove the air cleaner outlet duct.
5. If necessary, remove the engine sight shield.
6. Remove the radiator vent inlet hose from the radiator hose clips.
7. Reposition the inlet hose clamp at the water pump.
8. Remove the inlet hose from the water pump.
9. Remove the fan blade.
11. Reposition the outlet hose clamp at the water pump.
12. Remove the outlet hose from the water pump.
13. Reposition the surge tank outlet hose clamp at the water pump.
14. Remove the surge tank outlet hose from the water pump.
15. Reposition the heater inlet hose clamp at the water pump.
16. Remove the heater inlet hose from the water pump.
17. Remove the water pump bolts.
18. Remove the water pump and gaskets.
19. Discard the water pump gaskets
Installation Procedure Important: All gaskets surfaces are to be free of oil or other foreign material
during assembly.
1. Install the water pump and NEW gaskets
2. Install the water pump bolts.
3. Install the heater inlet hose to the water pump.
Zoom Sized for Print
Notice: Refer to Fastener Notice in Service and Precautions.
2.1. Tighten the bolts a first pass to 15 Nm (11 ft. lbs.).
2.2. Tighten the bolts a final pass to 30 Nm (22 ft. lbs.).
4. Position the heater inlet hose clamp at the water pump.
5. Install the surge tank outlet hose to the water pump.
6. Position the surge tank outlet hose clamp at the water pump.
7. Install the outlet hose to the water pump.
8. Position the outlet hose clamp at the water pump.
9. Install the accessory drive belt.
10. Install the fan blade.
11. Install the inlet hose to the water pump.
12. Position the inlet hose clamp at the water pump.
13. Install the engine vent inlet hose to the radiator hose clips.
14. If necessary, install the engine sight shield.
Important: Align the arrow at the throttle body end of the duct with the throttle
body attaching stud.
15. Install the air cleaner outlet duct
16. Install the radiator inlet hose clip to the outlet duct.
17. Tighten the air cleaner outlet duct clamps at these locations:
 Throttle body
 MAF/IAT sensor Tighten the clamps to 7 Nm (62 inch lbs.).
18. Fill the cooling system.
I hope this helps. The numbering is incorrect in the sequence but the instructions are correct.
Roy
Nov 06, 2009 | 2003 GMC Yukon
Water in the fuel tank wrangler 97
Sorry the isn't a drain plug on the fuel tank. Try this go to walmart or home depot and buy a kerosene can hand pump plastic cost $3 to $6 remove the hose coming from refill to tank cut off a piece of old water hose approx.5ft insert into tank from opening insert hard plastic portion of hand pump into water hose have something large enough to contain the fuel and start pumping open valve on pump to release pressure may have to pump several times to get it flowing good do not try to **** on hose pump will work once all gone reconnect hose and refill fuel with one bottle of Lucas fuel treatment and one bottle of Marvel Mistery Oil drive it all out refill fuel again with one last bottle of Lucas fuel treatment. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 22, 2009 | 1995 Jeep Wrangler
Drying problems
This usually indicates that the fill valve for the drying cycle is faulty. In short you need a new cold water valve assembly. (this will fix this issue 90% of the time) Otherwise you may need a new control board.
Inside of the machine (you will have to remove the top cover from the machine) is a valve assembly attached to the cold water line. This valve assembly consists of 2 or 3 individual valve bodies . The one on the right hand side of the assembly usually controls the cold water inlet for the drying cycle(this is necessary for proper condensation drying to take place). There is a black hose which attaches this part of the valve assembly to the wash drum. With the water shut off and the power removed from the machine, remove this hose from the valve and look to see if it has a small red (usually) plastic insert. This is a restricter insert which limits the water flow into the tub. Without the insert the tub will fill with cold water in a short amount of time.
Aug 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG LRFD25850 French Door Refrigerator Logo
161 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
