Question about ViewSonic VX2035WM LCD Monitor
Vx2035wm when i plug in the screen there is a box that says no singal ainalog and then the light turns from blue to a amber color and durning that i never see anything on the screen
  • 489 Answers
It sounds like your monitor is looking for an analog signal from the D-SUB connector while you are using the DVI connector. Go into the monitor's main menu and choose Input Select. Change the setting to Digital. You should now see yourr desktop.
Posted on Mar 28, 2009
  • ingram1225 Jun 17, 2011
    this monitor will not let you access the menu when their is no signal... ie the light is amber. I'm having the same issue. No digital signal on my new HD5570 Sapphire card. VGA works just fine. Other older or similar monitors DO capture a digital signal (DVI output) just not this monitor. My OLD nVidia 7600GT KO cards work just find with this monitor (DVI). Something is just not right here.
Why does my monitor say no signal when i turn it on
plug your VGA or DVI wire between your video card and your screen
Nov 10, 2012 | Computers & Internet
Flashing blue light
It could be a faulty cable
Sep 09, 2008 | ViewSonic VX2035WM LCD Monitor
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Wireless/LAN indicator on pc stays amber
best advice is as long as it's working don't try to fix it. you may cause more problems than you solve. as long as you get the internet ok, do you really care what color the light is?
Mar 07, 2009 | HP Pavilion G60-120US NoteBook
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Toshiba laptop
Try removing your battery for 10 mins then put it back in and restart. Let me know if this helps
Jul 30, 2008 | Computers & Internet
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
ViewSonic VX2035WM LCD Monitor Logo
411 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
