Question about Refrigerators
No cooling. just lots of warm air.
My fridge had a damaged fan around 3 years ago. i had it fixed and it has run fine since. today it stopped cooling completely. i get a lot of fan air. so it just stopped cooling completely. what should i test or look for?
i am capable of fixing anything. i know how to work with electronics, mechanics and some other things. i also have a can of r134a gas around that i can use to fill the fridge if needed.
  • 700 Answers
Is the compressor on? look in the back and make sure the its working . alspo make sur ethat the condenser coils are clean.
Posted on Feb 22, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
We have Jenn Air Built In Ref Model# JS48SEFXDA. We had the Power Supply Circuit part# AP4076255 replaced last year. We had a power outage 3 days ago. The fridge and freezer just quit cooling today. The...
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. Maytag/Jenn Air has one version, see diagram...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Jul 24, 2011 | Jenn-Air Refrigerators
The freezer has stopped cooling...meaning the fridge has stopped too. The fan continues to run, but blows warm air. Twice before the fan had frozen and stopped blowing the cold up to the fridge...we had...
replace the p.t.c. overload on the compressor body of the units compressor in the rear lower end of the unit,its not letting the compressor start and then not cooling
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
The outside metal around the freezer area is very warm.
We were informed that because of a lot of power outages and surges that the freezer was in constant defrost mode. Since the freezer had been in constant defrost for at least 5 days, we were told that the condenser would probably short out. Even though the fridge was 7 years new. We decided it would be cheaper in the long run to get a newer more energy efficient one, because we didn't know what other damage had been done and if fixing everything would just be too expensive and it could quit before everything was fixed.
Sep 13, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
