Question about IBM ThinkPad T30 2366 Notebook
No sound coming from my ibm t 30 speakers but if i put an earphon
If i place an earphone there is sound but not from the speakers
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
Hi. Greetings. I have one of this set. One day while i'm playing songs on it, my siblings accidentally plugged another wire into the earphone port. When i unplugged it, there isn't anymore sound...
Put a plug in the earphone port and wiggle it . Could be the little gadget inside is stuck. I had a tv that did that and ended up disconnecting the ear plug port.
Sep 21, 2017 | Altec Lansing VS4121 Computer Speakers
Cannot detect when a jack is plugged in.
check your sound card ,,do u have sound threw the pc speakers.if so bad head phones.or not compatable with your pc.
Oct 09, 2009 | Dell A215 Computer Speakers
The sound on both my old IBM laptops (T40 & X31) no longer work.
Try pressing the sound up button on the top of the keyborad. There are 3 buttons sound up, sound down and mute. It appears that the sound control on windows is independant of the buttons.
Apr 11, 2009 | Lenovo ThinkPad R51
IMB T42 Laptop Sound card quality is really poor what up grades
It's probably _not_ the soundcard (chipset), but the teeny little
crummy speakers built into the T42. On a thin, light laptop the manufacturers have to make some compromises, and one of them is that they give you miniature speakers that aren't much good for music reproduction.
The fix: either uses earphones or plug in external speakers into
the earphone jack. You can get pretty good, pretty cheap external speakers that give you fine sound.
Jan 13, 2009 | IBM ThinkPad T42 Notebook
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
-mate JAM Pocket PC Problem
Try putting in earphones and check. Sometimes the contact inside the earphone jack jams against each other and then the phone thinks there are earphones plugged in thus bypassing the speaker.
Oct 27, 2007 | i-mate JAM Pocket PC
IBM ThinkPad T30 2366 Notebook Logo
116 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
