Question about GE JGBS23 Gas Kitchen Range
OVEN TEMPERATURE TOO HOY
Oven temperature is about 50 degrees too high. We check it with an oven thermometer every time we use it. The adjustment on the knob is maxed to the cooler position. How do we adjust the thermostat?
  • 1,147 Answers
If its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Posted on Jun 20, 2009
Can't adjust oven thermostat
Has this just happened or have you suddenly just tested the oven temperature with a RELIABLE thermometer? Some cheaper thermometers can give a false reading. Check with a accurate thermometer first and place it at intervals in different parts of the oven ( it does vary) and take the average
Jan 17, 2014 | GE Profile JK915 Electric Single Oven
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
I bought an oven thermometer and it indicates that the oven temperature is approximately 100 degrees lower than the temperature set on the oven. Is there an adjustment to make so the set temperature is...
It sounds as if an element in the oven is not working do check again that the oven thermometer is on same scale as the oven settings farenheit or centigrade.Most likely it is an element fault.
Hope I helped.
May 07, 2010 | GE Profile JT915 Electric Single Oven
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Whirlpool oven 50 degrees too low
How do you know? Use an oven thermometer to check and leave it in for half an hour after the oven reports hitting temperature. Your manual should have a recalibration method.
Feb 25, 2009 | Kitchen Ranges
Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Jan 08, 2009 | Amana Ovens
I NEED TO ADJUST THE TEMPATURE OF A AMANDA OVEN! CAN YOU TELL ME HOW I VAN DO THIS?
the adjustment screw is behind the oven knob, remove the knob and in side the thermostat shaft you will find that screw. first you put an oven thermometer inside the oven at 250 degrees for about 20 minutes with out opening the oven door. now you know. if oven is to low turn that screw the same way the oven temperature goes high. about a quarter of and inch. if oven temperature is to high turn the screw the same way the oven temperature goes from high to low.
Dec 07, 2008 | Kitchen Ranges
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
GE JGBS23 Gas Kitchen Range Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
