Question about Ariens 34 In. Zoom Series Riding Mower
How do I adjust the belt on my Ariens 11528 snow thrower on the secondary drive, t will not throw snow
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    mr j whitch belt are you trying to adjust auger or drive belt.
  • Anonymous Mar 31, 2014
    Change belt on noma snowblower
  • 28 Answers
By the handle under the handel little ajustable rod
Posted on Feb 22, 2009
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
I have an Ariens 624 series snow blower and every time I use the snowblower the snow spits out of the chute. How do I get the snow to BLOW out of the chute far? I've tried tightening the cord for the...
Looks to me like your second stage is not working. If the auger is turning fine, look and see if the secondary thrower is turning. Probably a shear bold on one or the other is broken. Easy fix, but do not put your hands in there when the machine is running!
Jan 09, 2010 | Garden
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Ariens 34 In. Zoom Series Riding Mower Logo
536 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
