Question about IBM Deskstar 120GXP 40 GB Hard Drive
IBM Deskstar 120GXP 123.5GB
When i hook my deskstar hard drive up making sure that the cables are in the right spots and every possible combination of the pin my computer still does not find the hard drive in the bios. I have an Acer Aspire AM1641-U1521A.
    Champion:
  • 331 Answers
That model acer is a newer system; pentium dual-core; so bios limitations should not be an issue. With the 120GXP older drive; check that the 32GB jumper is right. The pins have a label (red text) on the back; ensure it is set to master (according to the far left label) not the right. It will take 2 jumpers; not just one. See how that works. Also, check your bios settings; and ensure the IDE power ... is enabled. (for example secondary) may be disabled. Or, check that "legacy" support is enabled in the bios. Please rank me if this helps. Please check me out on facebook http://facebook.com/techrx http://techrxgb.com
Posted on Jul 23, 2010
Deskstar harddrive
What is the model number of your unit?
Nov 01, 2012 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
Tip
How To Upgrade Your Own PC Hard Drive
At this point, the computer is powered off and I'm ready to add the new hard drive as a second hard drive. Since there is only one hard drive installed at the start of the upgrade, the old hard drive is already installed as the master hard drive on the first IDE cable. The new hard drive is added as the slave hard drive on the first IDE cable (the same IDE cable as the old hard drive, but using the slave IDE connector).
The first step is to set the jumpers on the back of the hard drive into the slave position. These pictures show the back of the hard drive which also contains a label indicating what each jumper settting means.
To get a close-up in which you can actually read the jumper label in the picture, I've taken two separate close-ups of the label and placed them side-by-side with the first showing the left-hand side of the label and the second showing the right-hand side of the label. Clicking on any picture makes an even larger image. For details of what each jumper setting means, see this Deskstar 120GXP Jumper Description at the IBM/Hitachi Storage Technical Support site.
It can be confusing to know how to set the jumpers just from looking at the label. As you read across the left-hand and right-hand pictures, you'll notice that a setting for "DEVICE 0 (MASTER)" appears twice. Same for "DEVICE 1 (SLAVE)". But the first mention applies to "16 HEADS" and the second mention applies to "32GB Clip". The Deskstar 120GXP Jumper Description does a good job of clearing up the confusion, so rather than repeat it here I'll just strongly recommend you give it a look.
Here are links to jumper information for other popuplar hard drive manufacturers. Western Digital Jumper Setting Information Maxtor. Once there, click on the particular hard drive model. Then select "Jumper Settings" and/or "Jumper Guide" in the [Technical Specifications] field. Seagate Jumper Setting Information. Look near the bottom of the page.
The default, shipped, jumper setting for the IBM Deskstar 120GXP 80GB jumpers is in the "16 HEAD", "DEVICE 0 (MASTER)" position and this is how mine arrived. Here's a close-up showing the jumpers circled in red. The IBM Deskstar 120GXP 80GB hard drive has nine jumper pins and two jumpers. The jumpers are white and rectangular in shape and are shown inserted over two pairs of pins. Notice the pins covered by the jumpers match the jumper label diagram as shown in the side-by-side pictures for "DEVICE 0 (MASTER)" next to "16 HEADS" . This is the correct jumper setting to use for the hard drive after the hard drive has been cloned and it is ready to become the Master hard drive.
But at this point in the hard drive upgrade procedure the new had drive is being added to my computer as the slave hard drive. Although the jumpers are small, you should be able to use just your fingers and move the jumpers such they are set into the slave position. In my case, that means setting them as shown here. Again, it can be confusing because the same picture shows, and right above the jumpers themselves, a jumper diagram labeled "DEVICE 1 (SLAVE)" which shows a different jumper setting. But that "DEVICE 1 (SLAVE)" jumper setting is for "32GB CLIP". Some computers (i.e., older computers) cannot use the whole 80GB and this jumper setting "clips" the hard drive down to a 32GB slave hard drive. My computer can use the full capacity of the hard drive. You'll notice the jumper positions in this picture match the jumper diagram for "DEVICE 1 (SLAVE)" next to "16 HEADS" shown in the previous side-by-side pictures.
Not all hard drives have the same jumper options and labeling as the Deskstar 120GXP. For example, here is a Western Digital WD1200JB (120GB) hard drive. Notice that the labeling is on top of the hard drive rather than on the rear. In addiition, there is only one jumper since the Western Digital does not support re-configuring the number of heads in the drive or the total size of the drive.
Hard Drive Upgrade Install Guide
The hard drive has holes on the side which are used for the mounting screws as shown here. Like most hard drives, the IBM Deskstar 120GXP 80GB has places for 6 screws, three on each side. On the IBM Deskstar 120GXP 80GB hard drive (and this was also true for my old IBM Deskstar 75GXP 45GB hard drive), some screws could be longer than others. In fact, three of the six screws could be longer since they had more clearance to the hard drive itself. For my hard drive upgrade and install, I used a total of six round-head machine screws, size 6-32. Three of the screws were 1/4 inch in length and three of the screws were 3/8 inch in length. Click on the picture to see it enlarged.
Here's a picture taken inside My Super PC before the new hard drive is installed. The case I use, the Antec KS-282, holds the 3.5 inch drives such as the hard drives inside a "drive cage". The drive cage is handy since it makes installing the hard drives a little easier. This picture shows the drive cage circled in red and the old hard drive which will eventually be replaced circled in blue. Click on the picture to see it enlarged.
Here's a closer view showing the contents of the drive cage before the new hard drive is installed and still containing the old hard drive. The backside of the old hard drive looks similar to the backside of the new had drive since both are IBM Deskstar hard drives, just different models. You can see the backside of the hard drive is in three sections. The leftmost section is where the IDE cable connects. The jumper pins are in the middle. You can see the jumpers on the old drive are set in the master position, which makes sense since it's the only hard drive in My Super PC. The rightmost section is for the power connector. Click on the picture to see it enlarged.
Install The Second Hard DriveLet's look again at the interior shot. I've circled the slave IDE connector. There are three connectors on the IDE cable and they are color coded. I've circled in red the gray connector on the IDE cable. This is the connector for the slave hard drive. The master hard drive connector is black and is still plugged into the old hard drive in the drive cage. The connector on the IDE cable which connects to the motherboard is colored blue. Click on the picture to see the picture enlarged.
The new hard drive will plug into this gray connector as the slave device. And you'll need a free 4-pin power connector like the one shown to connect the new hard drive to the power supply. Click on any picture to enlarge it. Like many things that connect inside the computer, both the IDE connector (the gray one, in this case) and the power connector are "keyed" by their shapes or some other means so that they cannot be plugged in "upside down". For example, if you enlarge the picture of the gray connector it's easy to see that the center of the connector includes a plastic bulge and a blocked out pin receptable to prevent it from being plugged in incorrectly.
This picture shows the backside of the hard drive where the connectors plug in. There are three sections on the backside of the hard drive. The leftmost section circled in red is where the IDE cable connects. The jumper pins are in the middle. The rightmost section circled in blue is for the power connector. Click on the picture to see it enlarged.
on Jun 29, 2010 | Computers & Internet
I have a Deskstar 80GB hard drive and I am adding another drive to the computer. How do I set the Deskstar to the Master. I'm not sure what the pin settings should be?
If you have the EIDE cables on your PC, it is easy. Your drives need to have their jumpers in the CBL SEL (cable select) positions (identified on the case on the sticker) and then you simply connect your Deskstar to the Master connector, and your other drive to the Slave connector.
Feb 12, 2011 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
I want to install a Hitachi Deskstar drive and the
Based on normal configurations, you should make sure that the pin settings on your main boot drive is set to master, and then make sure that your Deskstar is set to slave. If that doesn't work, then you might have a Bios setup issue. Let me know.
Thanks
Mark
Dec 18, 2009 | Intel D915GAG Socket 775 Motherboard -...
IBM deskstar 120 GXP 40GB will only format to 22GB. Its an old drive setup in an external usb enclosure
sounds like you're trying to format with FAT 16 or 32 which limits the partition size.
Try formatting with NFS which has no limit on partition sizes
Oct 25, 2009 | IBM Deskstar 120GXP 40 GB Hard Drive
Where can I find a XP driver for my IBM Deskstar 34GXP 20.5 GB ATA-100 Hard Drive (I have only the W98 version).
http://www.hitachigst.com/hdd/support/download.htm
quote " IBM today announced it has completed anagreement to combine its hard disk drive operations with Hitachi's,forming a new company called Hitachi Global Storage Technologies. " unquote. there is a link to the support site...you might have already been there..i don't know...here is another site but i think you will have to register...it has helped me alot.
http://www.driverguide.com/.....
you could also google xp driver cd . i have one and it also helps.
Aug 14, 2009 | IBM Deskstar 34GXP 20.5 GB ATA-100 Hard...
I have just removed a IBM Deskstar (DTLA-307015) from my desktop and installed into a external enclosure just turned it on and it worked without installing any drivers. I want to know is this set up right?...
since you said that the HDD works you have nothing nto worry, that means you have installed it correctly. as for clearing it up suggest you do a complete format. when you plug in the USB the pc will assign a drive name to it. note it down. the right click my computer/manage/disk managment(from the left panel) right click on the drive you noted down & format.
Mar 18, 2009 | IBM Deskstar 75GXP (DTLA-307015) 15.4 GB...
Installing Hiotachi Deskstar 400gb hard drive
in order to set it to slave you first needs to make sure the cable that u hoodked up to the hard drive is the slave not secondary then boot the computer to the bios and then under the ide section section you need to ensure that the hard drive is recognized as primary slave it will show the hard drive as a primary or a secondary that will let you you that u have the cable hooked up to the harddrive right if not usee the other connector on the same cabel and repeat the bios settings i know it sounds hard but it really is not good luck !!!!
Aug 09, 2008 | Computers & Internet
IBM Deskstar Model IC35L040AVVN0-0
Well, I guess your running windows XP ? If you open the disk manager, does it show up there ? When you reboot, does the Bios discover the drive ?
May 29, 2007 | IBM Deskstar 22GXP (DJNA-372200) Hard...
IBM Deskstar 120GXP 40 GB Hard Drive Logo
267 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
