Question about Dell Dimension 4600 PC Desktop
Chassis intruded asus m3a78-cm
A new motherboad at startup i get this error chassis intruded but no way to shut off
    Scholar:
  • 60 Answers
I actually did a little research on this one. I downloaded the User Manual for this board. USUALLY, there is a jumper on the board somewhere that needs to be set in the correct position. I looked through the manual and can't find a jumper for this . I even looked through the bios setting just in case it might be covered there, no luck. If you can't find an undocumented jumper on the board somewhere labeled something like TRPWR, then I would try the reset next. My suggestion would be to use the LCRTC jumper to reset the board. Heres the procedure according to page 1-17 of your manual:
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values.
Posted on Feb 22, 2009
    Scholar:
  • 69 Answers
I've read all the responses above, and none help. I have the same MoBo with the same problem. For you others, this jumper for the Chassis Intrusion is right next to the jumper for the CMOS Clearing (CLRTC) pins. Unfortunately there's no way to turn it off in the CMOS eitherr. Mine is set with the two close pins connected, and I'm getting the exact same response, even after resetting the CMOS. I took the jumper off, and same result. I think the mobo is messed up and am going to contact ASUS about it. It seems to be a common problem with this particular board.
Posted on Feb 13, 2010
  • Aleks_Dzog Sep 17, 2013
    I found the folowing solution:http://kanri-sha.livejournal.com/4268.ht... Or in two words - the method of only three easy steps: 1) Set the chassis jumper by default (3-4 pins of the chassis connecnor at the MB). 2) Switch off the power from the ~ 220 V, power supply or the MB, and set off the BIOS battery. 3) Move the CLRTC cap at the 2-3 pins. 4) Wait for the several seconds. 5) Move the CLRTC cap at the 1-2 pins. 6) Set on the BIOS battery and turn on the power. Good luck! :))
Hi
remove the CMOS battery and you should be good to go.
Cheers
James
Posted on Sep 09, 2009
  • 202 Answers
There is a setting in the BIOS of some motherboards that detects when the case has been opened. That can be useful in a corporate environment, but pretty much useless for home systems. It usually be F2 or DEL. Press that key. When the BIOS Setup opens, check the bottom of the screen for the navigation keys. Go through each page until you find the Intruder Detection setting. Once you find it, disable it. Save and exit the BIOS setup and the OS will start. The Intruder alert should be gone.
Good luck, and please let me know haow it works out for you!
Chassis intruded system halted in bios system
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key Enter Bios Go to Inter grated Peripherals Go to Onboard I/O setup Find "Chassis Opened warning" Set to "Disable" Press F10 to save and exit changes Hope this helps
Jan 22, 2013 | Computers & Internet
Data Breach SCDOR123
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Data and security breaches Businesses store vast amounts of information. A security breach occurs when an intruder, employee or outsider gets past an organization's security measures and policies to access the data. This sort of security breach could compromise the data and harm people. There are various state laws that require companies to notify people who could be affected by security breaches.
Physical Security Breach One form of breach is a physical security breach, wherein the intruder steals physical data, such as files or equipment that contains the data. Intruders could steal computers, particularly laptops, for this purpose. Businesses should monitor access to their property to cut down on such incidents and require employees to lock away their laptops when not in use. b> Electronic Security Breach b> Another form of breach is an electronic security breach, wherein the intruder gets into a business' systems to access sensitive data. The intruder gains such access by taking advantage of any weaknesses in the systems, such as inadequate firewall protection. This could also happen if the organization does not have adequate password protection for sensitive data. This sort of security breach is one reason businesses should perform constant security updates. b> Data Capture Security Breach b> Data capture, or skimming, is a practice whereby the intruder captures and records the data on a magnetic card stripe, such as on a credit card. This form of security breach helps the intruder produce copies of credit and debit cards. The intruder could either be an employee of a merchant who handles the customer's card, or it could be an external intruder. An external intruder could attach a device to card readers or ATM machines to skim information. b> Business Response b> Businesses should be wary of security breaches. Best practices for businesses to follow include having a policy in place to deal with any incidents of security breaches. They should identify what information has been compromised and decide who are the appropriate regulatory authorities to which they should report. Affected customers should also be notified. b> Potential Threats b> Start by identifying potential threats and vulnerabilities in your organization. Employees, temps or newly fired workers who have access to data represent one such threat. Hackers trying to crack your security are another. If your business or customer data passes into the hands of third parties -- vendors, business partners or bankers, for instance -- those parties may prove to be another weak spot. Review your security systems for any obvious flaws; Risk Analytics rates incorrectly configured firewalls as one of the top security threats. b> Calculating Risk b> Once you have a list of potential threats, document which ones represent serious risks. A low-level employee who doesn't have computer access poses less of a risk than an IT staffer with a grudge. If your company doesn't have data-handling procedures to prevent accidentally revealing customer data, that's another serious risk. When calculating the level of risk, consider all the potential negative effects, such as the loss of customers, the loss of money, having to shut down your network temporarily and the blow to your company's image. Security b> Once you document the breach risks, shore up your security to prevent them. Start with the most potentially catastrophic breaches. Preventing breaches requires more than encryption and other technical fixes: Consider the human side of security, such as employees who use easily hackable passwords or don't take security seriously. Think about the security of your business partners' operation as well as your own. If you encrypt key data and carefully regulate access, you still have a problem if your partners don't follow equally strict policies. b> Rethinking b> Never assume that, once you've documented your breach risks, you can rest easy. The information technology landscape changes constantly, creating new vulnerabilities. Mobile-payment technologies that allow shoppers to make credit and debit purchases with smartphones, for instance, are a new field. The field is growing steadily, but it lacks any common security standard. The apps are easy to develop, but developers do not always make security a priority. Review the risks created by new technology if you want to stay on top of new breach dangers. Hope this helps
b>
Dec 31, 2012 | Computers & Internet
My Lenovo 3000 J Series switches itself off at startup before the opening of Windows xp. Any ideas? This message is from another pc.
the problem of power off after startup can be caused by:
  1. a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
  2. Cpu fan problem, the CPU temperature is abnormal
  3. faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate. then clean the radiator and the fan. if the problem still not solved change your motherboad.
Dec 13, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
I am getting the fatal error chasis intruded error on every boot...motherboard model is p5sd2vm...rahul
Chassis intrusion can be disabled one of two ways.
First, Check your bios settings. There should be a security or PC health section where you can clear that error and disable the intrusion warning.
Second, there is likely a small switch near the chassis side when the side panel is removed. This is the chassis intrusion switch. It will likely lead to a 2 or 3-pin connection on the motherboard. this can be disconected without any ill effects.
Aug 13, 2010 | Computers & Internet
CHASSIS INTRUDED
reset your bios settings .
put your cmos cell on mother bord for 15 minutes remove it from bord.
then it reset to factory defaults settings.
Apr 24, 2009 | Computers & Internet
Chassis intruded
Hi
this is a setting that needs to be reset in the bios.
when you turn the computer on, at somepart of the screen the computer will say press this button to enter setup or bios. press the button when asked to enter bios. in bios you will need to find case intrusion detection and turn it off. Its probably in the monitoring part of the bios.
t will take too long to locate the correct manual for your computer but I took another computers manual and the bios settings may be a little diffrent but basicly.
this should be in the H/W monitoring page.
we are looking for chassis intrusion, turning that to disabled or off will remove the problem your facing. ones you have turned it off you should be able to turn it on the next time you start up and it shouldn't complain unless the case is opened again.
Its a good protection in a public enviroment, for example a employee might steal some ram from a computer or other parts with this feature enable the owner of the pc will be aware that someone has been inside and will check the internals.
Its not very useless at home since its very unlikely to happen but there are people out there who might do this at work or other public places.
Let me know if you need anything else.
Thanks,
Ekse
Feb 22, 2009 | Dell Dimension 4600 PC Desktop
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Hi I cannot shut down my computer,even after i go to start, shut down etc it then gives me an error" a fatal exception OE has occurred at 0028:COZA27AB, etc Then the current application will be terminated
OE usually mean outlook express. If you use that, you may want to look at deleting the profile and creating a new one.
Also click star-->run. type msconfig. In the startup tab disable all non essential apps.
Jul 28, 2008 | Computers & Internet
Problem at boot
plz disable the chassis open warning option in the bios.
Apr 21, 2008 | Computers & Internet
Cooling fan error(hp III small factor)
what you should do, go to electronic shop and buy a new fan because sometimes you may loose your motherboad or maybe its the rear fan just purchase a new fan tha'ts the solution nothing else.
Mar 26, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
1,943 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
