Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
VACUUM HAS NEVER HAD VERY GOOD SUCTION FROM DAY ONE.
A cheaper vacuum over the same area picks up more. Now brush does not work.
  • 150 Answers
You will need to turn it over and unscrew the plate where your beater bar is,relpace the belt and while your there clean out all lint and build up especially the intake tube.And change the bag.
Len
Posted on Feb 22, 2009
Air not getting to hose
I'm not sure which model you have but this is good for Riccar upright vacuums. If the hose has good suction but is not picking up well check the suction tube that is down by the brush roll. The suction tube starts by the brush roll and goes to the back of the vacuum where you put the suction hose into. If it has a clog or restriction the vacuum will not pick up properly.
Mar 12, 2014 | Riccar Vacuums
Problems with suction on floor of vac
Often times when people bring a vac in for repairs and say it has no suction at the floor it has good suction but not good agitation. Make sure the belts in the clutch are new (some people are selling used clutches with stretched out belts) and the brush roll is good. If the agitation from the brush roll is not good it will not pick up even light soils like hair and lint.
Oct 08, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Does not pick up lint on carpet
I have a four suggestions. First, check the wand and see if the suction vent is completely closed. If this little vent has the slightest opening, the suction is reduced. cSecond,if that's not the case, you might want to check the brush/roller area. Threads and fibers caught on the brushes can prevent the vacuum from picking up lint. Third, make sure there are no fibers in the wheel of the vacuum head. And fourth, make sure the bag is not full! I often forget to check and back and a full bag is one of the main reasons a vacuum will not pick up items. I hope this helps. If one of my suggestions solves your problem, please contact Fixya and rate my solution!
Nov 21, 2010 | Kenmore 23313 Whispertone Bagged Canister...
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Wont pick up
Mine was doing this soon after I bought it. I had to cut the strings, and hair off the brush...cleaned the filter (plastic one) and then it seemed to do better. I still have problems with it getting clogged in the tube once in a while...I usually take a broom stick and push it through...I also have a Kirby, I tell ya I am thinking of spending the money to have it fixed because these cheaper ones aren't very good.
May 04, 2008 | Hoover U5753-900 WindTunnel Bagless...
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not picking up
Did you check down by the brush roll? If the hose has suction, then the problem has to be in the nozzle asm. The hose having suction tells you that the main part of the vacuum is working ok.
Mar 17, 2008 | Eureka 7618 Bagged Upright Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
48 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
