Question about Philips Magnavox 51MP392H Rear Projection Television
I have a 52" projection tv it is a phillips. one day i came home and i went to turn it on. now what do i do it wont turn on?
  • wellb1873 Mar 06, 2009
    i have a similar problem only mine turns on every so often for about two min then shuts back off
  • Philips Master
  • 5,568 Answers
In the absence of any warnings of impending failure, the main power supply has probably failed.
This is likely to be a separate assembly (board) that you could replace on your own. If you remove the back lower panel, follow the AC cord to locate the supply, get the part number from the assembly (there may be two different numbers). The bare circuit board may have a number that was printed in the same manner as the component identifiers and then another number on a label which might contain a 'revision' number too. This board is probably not terribly tought to repair with the necessary instruments but you would be better off buying a new board and then looking for someone to repair the other since it will probably be needed when the replacement fails.
Posted on Feb 22, 2009
My tv wont turn on
Jan 06, 2013 | RCA P52926 52" Rear Projection Television
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Phillips cineos 52 inch have sound but no picture
i have a 52 projection tv phillip and the pic is off you see three images on the bottom nice pic in the middle and on top a little what is the problem
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Tv will not start up
does the front led flash. if it doesnt then you may have a primary power problem.. the fuse may have blowed,., this ussally means other componets have shorted IF the led flashes then you have a processor shutdown
Dec 31, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic 52 in cianema vision how to make second channel appear in corner
I turned my tv on one day and the screen just went to like times 100 in size so i replaced the bulb not the problem how do i fix it
Nov 02, 2008 | Panasonic PT-52DL10 52" Rear Projection...
No power
Good Day, jennylo04;
You need help??? I need help, too!!
Please help me by providing a MODEL NUMBER. OKAY??
Thank you, big IRISH,.
Aug 07, 2008 | Televison & Video
Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
