Question about Food Processors
Durabrand 2 in 1 food processor
My food processor will not power on for either side. What could be wrong? It is practically brand new,only used a few times.
SOURCE: Replace Rubber 0 Ring for GE Food Processor Inside Diameter 2 6/8
I decided to trash my 19 year old GE Food Processor that needs a new gasget and puchase another.
Thanks for your interest.
Samella 124
Posted on Apr 10, 2009
yecalam13
  • 41 Answers
SOURCE: brand new food processor does not start
not sure what type you have. some have a tab/tang on the lid that when turned locks into side of processor. this is a safety switch. check lid for this. hope this helps. if not return for an exchange.
Posted on Aug 23, 2009
Testimonial: "Thanks, that was it... the top piece packed backwords, when I reassembled it properly, it worked."
SOURCE: I have a Waring food processor model FP51071 motor will not go on
since I did not get a response from fix it and could not find a local repair store from fix it I called Waring the manufacturer and was told the motor will not work as a safety precauition until the top is locked in once I did that it worked fine.
If you had responded to me in anyway except to sign up and pay for your service I would have signed up now I am just annoyed .
Posted on Nov 12, 2009
heatman101
  • 43501 Answers
SOURCE: I bought this food processor brand new and used it
Make sure that the cup is inserted properly and that it activates the switch...
Also make sure there is no debris in there that could block it from going in the whole way... it is very sensitive...
If that is not the problem, then return the unit... it has at least a 1 year warranty on it from the manufacturer..
heatman101
Posted on Jan 16, 2011
  • 8 Answers
SOURCE: My cusinart 14 cup food
Improper positioning of bowl, lid and pushers will not close the safety interlock switch. Read the manual.
Posted on Jan 29, 2011
I have Durabrand model # XB9018 food processor and i need a new lid. Where can i get one
You must contact the manufacturer of the product to obtain any parts if they are even made, which I doubt. But give it a try.
Nov 22, 2016 | Food Processors
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
Fuse?I bought this processor here in Saudi Arabia, unpacked it and put it in my cabinets. A couple months later I went to use it and the damn thing doesn't turn on. I think maybe the 13 amp fuse in the...
Hopefully you have or know someone who has an ohmmeter or a multimeter. You can check the fuse by measuring the resistance of the fuse. It should be zero or close to it. If it reads high, in the kilo or meg ohms, then it is open or bad. I checked Wikopedia for the Saudi Arabia's
voltage source, and it lists 120v 60cycle and 220v 60 cycle. If the food processor is a 220v 60 cycle piece of equipment, it may not appear to work on our (the USA) 120v 60 cycle power.
Nov 26, 2009 | Kenwood Food Processors
Brand new food processor does not start Trying this for the first time just out of the box. No power. Tried both the "on" and "pulse" settings. (and yes, the outlet has power)
Aug 23, 2009 | Cuisinart Food Processors
Can you slice almonds on the cuisinart dfp 3 if so how?
It is very difficult, but the machine is capable of it. Use the chopping/mixing blade (S-shaped blade). You would place a small amount - about a small handful - in the workbowl, and pulse the almonds only for about 2 seconds. Even if you want to eventually chop a large quantity, only do about a small handful at a time. It is so difficult, because the almonds will be completely pulverized if you leave it on for even 3-4 seconds. Many people who try chopping almonds, nuts, etc in a food processor discontinue the practice b/c it is so easy to overchop them into dust.
Apr 19, 2009 | Cuisinart DFP-3 Handy Prep 3 Cups Food...
Wrong card
If you were given the wrong registration card, go to Moulinex's website and get the right contact phone number - they can either register you over the phone or send you a registration card. Having worked in consumer electronics, I can tell you that the registration is practically worthless - save your receipt instead. The serial number will carry for a part of the warranty period, and after that period they will require a receipt even if you have registered. But the website for finding the contact info is here:
http://www.moulinex.com/services/international-contacts/international-contacts.htm
-Tha Mp3 Doctor
Dec 31, 2008 | Moulinex DG6 Food Processor
Euro pro food processor and blender combo
Defective pulse button or blender attachment not installed correctly.
Sep 12, 2017 | Euro-Pro EKP110 6.25 Cups Food Processor
Appears to be locked but won't turn on
ah! well my mother just tried using her DLC-10S 7 cup food processor and she also encountered the same problem. It worked perfectly fine when she first used it around Christmas time but not anymore.
After almost smacking the hell out of it we discovered that there is a plastic tab on the lid towards the handle side. This plastic tab actually pushes a lever through the cup and into the base of the food processor.
New Bee actually mentions this above. The problem is that the flimsy plastic tab in the handle isn't stiff enough to push the lever down anymore. I'm amazed it worked the first time.
This is very much a design flaw by Cuisinart as there's no way this plastic tab would ever last.
Now there is a small opening in the case right above the plastic tab. To get our food processor going we just pushed a chopstick down on the tab and held it in place while the food processor runs.
This is very much a temporary solution until we get a new food processor, obviously a different model.
Nov 22, 2007 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
255 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
