Cannot log in
I turned on my computer and i get error message saying due to tampering I cannot log in
  • Anonymous Apr 24, 2009
    System error, System has been tampered with. I can't get the bios or anything to come up
  • RescueTechLA
    RescueTechLA May 11, 2010
    What kind of a computer is it?
Key selection error VX670 TAMPER LOG F5
Tamper is cause by the bad internal/system battery that need to be replaced or you a bad plastic case which triggers the internal sensor on. We need to reload the Verifone Software to clear the tamper error. If you still need help you can call (775) 358-2922 ask for Randy. Thank you. http://freshpoint.org
Oct 15, 2012 | VeriFone Omni 3700
Dropped my nurit 8020 on the ground. Now when I turn it on, the first screen says self test please wait followed by the machine info and secured. Then it goes to a screen that reads tampered device/alarm...
To make it useable we need to remove the tamper first. Nurit OSP Loader is the the program we use to remove the TAMPER error. Replacing the internal battery and reloading a fresh NOS (nurit operating system) will remove the error. Check our website at freshpoint.org or cal us if you can at (775)358-2922 . It can be fixed, you don't need to replace it. thank you.
hope this help : - )
Jun 12, 2011 | VeriFone (M19755014US1) Magnetic Card...
I keep getting an error message when I tern on my terminal that says **DEFAULT CERTIFICATE TAMPER** that keeps blinking. I have a Verifone VX570 credit card terminal and my merchant account company is...
you will most likely need to get a new signed certificate from the vendor, the certificates are used for secure transmission between the card processing company and you. Give them a call, they should be able to issue you a new cert and get you going again.
Jul 09, 2010 | Computers & Internet
Iget yhe Yahoo page. It says
this can be due to two reasons.
first if you are trying to sign in ... it is possible that someone has logged on with you id so yahoo is denying another logon attempt. sometimes trying to log on when yahoo messenger is also logged in at the same time gives this error message. seleting temporary internet files can also help.
otherwise if this message comes up when trying to make a new yahoo id .. it simply means it is taken by someone else so try some other id.
Aug 07, 2009 | Microsoft Windows Vista Home Premium for...
Error Message - Failed to get data for SchemeAC
This is generated by a program that is run at start-up and it is being denied access to a resource due to the permissions of the user. As long as it isn't a critical app (probably isn't), you can just ignore it or if your feel courageous, you can investigate by downloading autoruns.zip from the Microsoft website. It is a utility developed by SysInterrnals (bought by MS s few years back) that will display every program that starts up through entries in the registry, start-up files (autoexec.bat), and a host of other ways. By going to the Logon tab, you can see what was started when this user logged into the system. Look for anything that says SchemeAC and disable it. Log out and login again. The error message should not appear. This needs to be done for the current user only, not the Administrator.
Mar 26, 2009 | Acer Aspire 1681WLMi Notebook
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
Unfamiliar Error message:
This seems to be related to a network problem, specifically, authentication. Has anything been changed or upgraded recently? There are a number of references to the error on the internet. I have attached them below.
Firstly, one user has looked at the /var/log/messages log file and found the additional error "uam: uam not found (status=-1"
Can you check that log?
A fix suggested by one user is:
"Turns out I needed to update the nettalk version that was included with YDL 2.3 to version 1.5.3.1-1c. After that and a restart apple talk works perfectly, on both our os9 and X machines." Maybe there is a lead there.
Attached bits from other users below.
Apparently, this error is "-5002 afpBadUAM: AFP Bad UAM," something to do with the User Authentication Module.
I've looked in var/log/messages
>>and it says : uam: uam not found (status=-1)
http://www.yellowdoglinux.com/support/solutions/ydl_2.3/netatalk.shtml
Good Luck. If you need to talk further, pls post it here. Rgds,
May 08, 2008 | Apple MacBook Pro Laptop Computer with...
Can not add or remove a program from my computer.
Log off and Log back on as an administrator. You are most likely logged on as a user with limited privilages.
Feb 27, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
