Question about iLO 2600 Television
Need universal code for ilo dtv2794 tv set
The original remote that came with the tv stopped working all of a sudden and I can't change to aux mode to watch dvd's. I can't seem to find a universal remote that has the code for this television. I'm going crazy please help. The tv is only 2yrs old and I do not want to chuck it. Please, please, please help.
4 Suggested Answers
SOURCE: ilo tv
The Sony RMV210 remote will work on the 32inch Ilo and other HD tv's, that what makes it cost so much, but it will work
Posted on Nov 24, 2007
  • 3 Answers
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
Posted on Aug 06, 2008
Tech5508
  • 40 Answers
SOURCE: need codes for universal remote for ilo television
I dont know which remote you are using but you might want to try these 2 codes... 0171 and 1990
These codes are also mentioned depending on which universal remote being used ...
10180 10171 10171 10179
Good Luck.
Posted on Feb 10, 2009
  • 5 Answers
SOURCE: what universal remote
This TV is made by Orion, some of the Orion codes may work with it. I had my Dish remote working with it. The mute and video imput functions did not work. If you can get a cable remote 1056B01 made by URC you can do a code scan. One of the codes works for this tv.
If you need the original remote that came with this TV email or call Orion support http://www.orionsalesinc.com . You can also find them on Ebay.
Posted on Feb 23, 2009
Tv stuck on video output universal remote works but not changing tv/video out put
If your iLO TV worked with your universal remote and now doesn't, remove the batteries from the remote and push all the buttons in case one is stuck then reinstall the batteries and program it again with the iLO code
Dec 17, 2012 | iLO Televison & Video
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
I have an ILO tv 32" I need to repalce the remote
The GE universal remote #24914 works to change your Ilo tv from analog to digital. The code is in the book that comes with the remote (code: 0189). I use this remote myself. It works just as good as the original ilo remote. This remote can be bought at Target for under $10.
Jun 14, 2010 | iLO IWT3206 TV
Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Jul 30, 2009 | Durabrand DWT1905 TV
I HAVE A PHILIPS UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM IT TO A ILO TV. AND ALL I KNOW IS BY THE BATTERIES IT HAS CL019.
It is highly unlikely that if you had the code book that there would be an Ilo code. You have three options:
Option one is to purchase a high end universal remote that has an auto search feature for the correct code, since Ilo is unlikely to be one of the offered codes. Ilo does not build their own tvs, but vends out manufacturing of the sub assemblies and puts their name on it.
Option two is to go online directly to Ilo and purchase the original remote. Be prepared for sticker shock. Original remotes can be expensive.
Option three is use an external tuning system to your tv such as a cable box or vcr which will allow you to change channels remotely using the remote that controls the device. Many cable company boxes have remotes that also control the volume and on/off functions.
Apr 28, 2009 | Philips Magnavox Learning Universal Remote
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Need remote control code fro iLo TV
iLo Tv's are made by orion. When I used their code the Tv remote worked.
Dec 07, 2008 | iLO 2600 Television
Ilo tv
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Universal Remote HELP!!
try all the code you have for the tv if that does not work then you will have to get the originald remote for your tv.for a originald remote try www.partstore.com good luck.
Jun 04, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
415 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
