Question about Sony Playstation 3 (PS3) Console
Problem connecting controller for ps3
I just bought a wireless controller from psyclone essentials. It wont connect to my ps3, any suggestions?
    President:
  • 2,653 Answers
Easiest thing might be to just return it for another one or check their website to see if there is a hard reset somewhere on the controller.
Posted on Feb 22, 2009
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont recognize my dual shock controller
You just need to connect the controller to the PS3 with the USB cable and it will fix the problem!
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont connect to internet
Your PS3 should have WiFi built in unless you bought he 20GB version back when it first came out, that is the only one that dosn't have WiFi. But you can still connect it the way you want. You can use any type of ethernet cable, straight through or crossover. You need to go into your network connections in the control panel, select wired and wireless connection at the same time and bridge them. That should do it if you wanna go that route but you would have to have the computer on anytime you wanted to connect your ps3 to the internet. The best bet I think would be to just use the WiFi built into the PS3
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wireless connection
i would suggest logging on to your home pc, checking the wireless settings then re-entering them into the PS3 internet settings, this happened to a familys PS3, but this solved it
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 controller wont connect with my ps3
Brian,
If after connecting to the USB it still won't work wireless, the best thing to do is this:
1 - Connect the controller to the PS3, via USB
2 - Click the PS Button to turn on the system
3 - On the XMB screen, click the PS Button again. You'll get the options, to "Turn off the controller". Do that and then turn it on again. It will reconnect with your PS3.
Regards,
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Psyclone essentials ps3 wirless remote controller wont connect
just fixed mine. i went to psclones web site ...it doesn't even have the PS3 remote listed a s a product!! however by reading the PS2 manual i figured that if I basically adapted the instructions it might help...I moved the remote to the 3rd slot.. turned off controller switch... held connect button on reciever... turned on controller.... held connect button....held select button ......held down left analogue stick....in no particular order...going back and forth until i noticed the lights had started to go steady... kept holding (30 secs+) Saw a single steady red on 3rd slot...It stayed...Yeh ;O (no clue what was the deciding factor...but theres hope!!) Lesson learned..next time i pay the full price for the Sony remote... Hope this helps
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
How to wire a ps3
Hey allisc,
In order to connect your PS3 to the internet, you will need one of two things: a hard-wired connection, or a wireless residential gateway. Please keep in mind that your options may be limited by the PS3 model that you own, and that a wireless connection is not possible with some models.
The most straight-forward type of connection you can make is a hard-wired connection - simply use an Ethernet cable to connect your PS3 directly to your residential gateway. By establishing a direct connection, the PS3 should not need any additional information in order to access the internet. The trade-off for the simplicity of a hard-wired connection is that the number of places you can physically place the PS3 itself are limited by the length of Ethernet cable used.
Should you wish to use a wireless connection instead, you will need to own a 40GB, 60GB or 80GB PS3 and a wireless residential gateway. The 20GB model unfortunately does not support wireless capabilities at this time. Please keep in mind that connecting wirelessly can often prove to be more complex than using a direct connection, as you not only need the name of your router, but information on any established security settings as well.
The most common security settings that may be in place are Wi-Fi Protected Access (WPA) keys and Media Access Control (MAC) filters. MAC filters are essentially a series of "blacklists" and "whitelists" that restrict network access based on hardware configuration. WPA keys however, are "passwords" that allow your computer or video game console to decipher a code used by residential gateways which prevent unauthorized users from using your personal internet connection.
Both forms of security may typically be set and changed by accessing the gateway directly through its default website. This default website can vary depending on the brand of the device, but many companies may use one of the two default addresses I've provided below:
192.168.0.1
or
192.168.1.1
Please keep in mind that in order to access the gateway's control panel you will need to have both the admin user name and password!
Once you have gotten access to your residential gateway's control panel, you should then be able to add the MAC address of your PS3 to the gateway’s MAC filters, as well as copy down any WPA key used by the network so that you may later enter it into your PS3's memory.
If you are still not sure how to proceed or do not feel comfortable doing any of this, I would strongly suggest contacting either your internet service provider (ISP) or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
261 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
