How does one adjust the park brake on a 2003 Duramax 2500HD. All four wheels have disk brakes. I have traced the cable out and there is no adjustment on the cable except possibly within the rear brake assembly itself or at the emergency brake peddle in the cab of the truck.
Park Brake Adjustment (Disc Brake)
Tools Required
j 21177-A Drum-to-Brake Shoe Clearance Gage
Park Brake Shoe Adjustment
Caution: Refer to Brake Dust Caution.
Important: The park brake shoes must be adjusted before the park brake cable tension is adjusted.Set the J 21177-A so it contacts the inside diameter of the rotor
Park Brake Cable Tension Adjustment
Important: Before you adjust the park brake cable tension, verify that the park brake shoes are adjusted to provide a clearance of 0.6604 mm (0.026 in) and the rear disc brake rotors are installed.
04 Silverado 1500 4x4 disk all around..Parking brake goes all the way to the floor and with a little gas I can drive right throught it.Dont seem enough to hold the truck and 4000 lb boat on the boat ramp tight to set the truck in park.Dealed says it's within specs..I say its to loose..Can you help on the adjustment andmaybe a picture of the adjuster
location of park brake adjuster for Mitsubishi magna 1997 and how to
