Question about Kenmore 15944 Top Load Washer
Washer won't agitate or spin
I have a Kenmore washer model # 110.92588210. It runs through all the cycles fine but will not agitate or spin. The water just runs in and out leaving the clothes sopping wet. I have gotten as far as removing the cabinet but now I do not know what to do. Can you help me identify the problem so I can purchase the right part? I am a novice at this - should I call a repair person or can I continue on my own?
Thanks
  • 188 Answers
Check for a broken or worn motor coupling (behind the motor), it connects the motor to the transmission. If your even a little handy, you should be able to replace it on your own.
Let me know if you need any guidance.
Posted on Feb 22, 2009
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Apr 20, 2009 | Kenmore 24032\24036 Top Load Washer
Spins slow or not at all, in the spin cycle.
Remove the water pump and check for a blockage in the pump.
If no pump problem replace the brake and the drive coupling.
Feb 22, 2009 | Kenmore 23012 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 15944 Top Load Washer Logo
171 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
