Question about Kirby G4 Bagged Upright Vacuum
Right angle grinder starting to smell like burning electrics, bad armature or bad field. Which goes first?
  • royzee May 11, 2010
    Sorry what do you mean by angle grinder?
  • 281 Answers
Usually the brushes will go bad first
Posted on Apr 13, 2009
    PETE GALATI Apr 13, 2009
    look at the aemature and see if there is a lot of dirt or burn marks.if there are burn marks you might be able to take a smsll strip of emery cloth and go over the armature real lightly,then take a brush and bursh out the little tracks on the armature.if you have some contact cleaner you can try to spray a little on a cloth and wipe it clean.
Is there a fuse or circuit braker in a sunline SM-G31 grinder?
Hate to say it but I fear the windings have burnt and is in need of repair. Any burning smell or smell of heating is most of the time directly related to armature or burnt brushes. If this grinder suits your needs having it rewound would be profitable.
Mar 26, 2016 | Vacuums
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
Switched on my dyson dc 14, but suddenly started to splutter, smell of burning, i switched it off and now it wont switch back on. i have changed the fuse.
Burning smell is NOT good. Sounds like an electrical short in the motor field windings. You'll have to take the machine apart to locate where the damage occurred and see what can possibly be repaired or needs to be replaced.
Oct 14, 2013 | Vacuums
Kirby sparks and smells
it probably needs new carbon brushes in the motor,DO NOT run anymore for fear of burning motor out.
Jan 16, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
My e-2 vacuum runs very loud and smell like it's burning.
You may have damaged a bearing or bearing housing and that could be causing the motor armature and field to rub together which in turn causes the motor to draw a significantly increased current to overcome the friction. It could be a simple fix if it is a bearing but if it is the housing then it is likely toast. I used to repair motors years ago and the cost then was not bad. However if the motor is heat damaged, as happened to my power rack last year, it was cheaper to buy a new one than replace the motor. A burned out motor is not worth repairing these days.
Dec 19, 2017 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series
The belt looses it tensile strength (tightness) over time. But it's the part about funny sounds and shutting down that concerns me. If it smells like a tire fire then it's the belt if it smells like plastic and burned hair then the motor has a bad field or armature. Probably one of the carbon brushes got hung up and burned a segment in the armature.
Oct 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Kirby G4 Bagged Upright Vacuum Logo
215 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
