Question about Kenmore 62602 Electric Dryer
Water in the vent hose ? And not heating fast or normal.
When preparing to check out the dryer, upon pulling it out from wall, water was coming ( assume) from the vent at the dryer outlet, the vent was twisted. But water? Ty Mr. Walker
  • 547 Answers
If the vent was cloesed off the heat and moisture would cause condensation that would pool in bottom of hose
Posted on Feb 22, 2009
  • albert getty
    albert getty Feb 22, 2009
    as well if vent blocked off would take longer to dry
Heat/defroster doesn't work. blower does.
As far as heat, does the engine reach normal operating temp? Do the heater hoses get hot? Can you check circulation through the heater core?
Check the actuator doors under the dash, see if properly operating?
Oct 14, 2016 | 2000 Pontiac Grand Am GT
Water coming out of the back of the dryer
When a dryer usually produces visable water from any part of it's self, the suggestion would be a completely restricted vent line. Such restrictions could be from nests from animals, excess lint, a dip in the vent hose causing lint and water to collect. Since the dryer is leaking water, it is heating and therefore creting steam in an effort to dry the cloths, with a clogged vent the steam has no where to escape to and thus condenses within the dryer and leaks out. The vent needs to be checked by a wualified vent servicing company from the back of the dryer to the point of exit of the home. Pleazer Appliance...
Jan 13, 2015 | Maytag Neptune MAH5500B Front Load Washer
My dryer is new it's leaking water and not drying clothes it's bush tdv6w
you have a plugged vent from the wall somewhere to where it goes to the outside , the way to tell is to unhook the vent hose run dryer through normal cycle and see if cloths dry
Nov 24, 2013 | Dryers
My dryer does not heat. Clothes do not dry.
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose. If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Dec 06, 2010 | Kenmore Dryers
Water builds up in vent hose from dryer to wall. what would cause that?
easy solution, your vent exhaust is clogged, the heat and water extracting from clothes is staying inside your vent
Mar 07, 2010 | Kenmore Elite HE4 Electric Dryer
Getting a lot of condensation at wall where the dryer vent attaches, we have moved and the new house has a smaller laundry room. The first time we used the dryer I noticed a puddle of water, checked washer...
My suspicion is that the damper on the dryer vent is not completely closing, allowing the cold air to pass into the house. Also check to see if the vent hose is sealed to the vent with duct tape or steel tape.
Feb 22, 2010 | GE WSXH208A Front Load Washer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
Not drying clothes, heat is on, lots of moisture in dryer
hi there,
This is a classic sign that you need to unclog or improve the dryer venting to the outside of the building.
One of the most important functions of a dryer is the elimination of moisture recovered during the heating of damp clothing. A typical 12-pound load of laundry can weight as much as 20-pounds when first removed from a washer. The extra 8-pounds is water. That moisture is held as humidity in the warm air produced by the dryer and is normally expelled to the outdoors through the dryer's vent. If this air can not be adequately removed, poor drying will result.
This moisture can also condense into pools of water in the dryer vent, eventually leaking out. Moisture accumulation inside the dryer ducting is often a sign of poor venting which should be looked into
good luck!!
thanks
Jul 07, 2009 | Kenmore Dryers
Kenmore 62602 Electric Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
