Question about Sanyo DP32746 32 in. LCD Television
My sanyo dp32746 clicks on, screen flashes, has sound but no pic
When I turn on my dp32746 I get sound & no picture. Upon opening up the unit I discovered one of the 2 fuses on the inverter bd blown. Further investigation led me to find Q19 was shorted. My problem is I cannot find the replacement # for this I.C. The only #'s I have are 4614 & BD6E3P it is an 8 pin SOIC surface mount I.C. The chip itself has an "A" symbol on it. Does anyone know the manufacturer or the prefex to 4614 of this SOIC. Thanks Tom
    Sergeant:
  • 227 Answers
The 4614 # when ordering.
Here is a possible link.
http://www.audiolabga.com/mal_cart/mal_cart.php
Hope this is a Fix Ya........
Posted on Feb 22, 2009
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
Sanyo dp32746 32in.... is making clicking noise when you try to turn it on ..... no picture on screen or sound practically dead. Took back off it is clickin around the bottom left corner of the board that...
hi
the common procedure is to replace 1 or 2
capacitor on the board i would suggest to take the board out and take it to your local repair shop and they'll know what to do
Sep 30, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Dec 10, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
No picture
Sounds like one of the CCFL's is failing.. (Backlight bulbs).. Some use multiples and others have singular.
Feb 29, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
209 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
