Need free owner's manual for a Detrola record player Model KM837
The piece that attaches to the arm that turns the turntable on has come loose and I need a diagram to show me how to put it back in order to get my turntable to work. Can some one please help? My mom was given one of these from a friend's dad who passed away recently. It seems to work great, but we'd like an owner's manual so we can figure out how to work everything.
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Posted on Apr 22, 2009
  • 2 more comments
  • blueyes7363 Sep 24, 2011
    Thanks so much. We were pretty much in the same predicament; received the product from a estate sale and had no manual. Now we just need to figure out how to get the CD drawer to open. Any suggestions??
  • Beverly Moore
    Beverly Moore Dec 21, 2011
    OMG!!! Thank you soooo much tomtuiace. I recieved one of these for Christmas and it played 5 albums then quit. I cried :o( Then today I found your solution and it works. MERRY CHRISTMAS!!! and thanks again.
  • dredogg617 Sep 03, 2013
    thats exactly what happened, I moved the arm to the right and it began turning and playing again... thanks so much for the tip...
  • Barby
    Barby Oct 31, 2013
    THANK YOU! It works now. Such a simple thing - I was so bummed, and now I'm so happy!
Hope this helps everyone. I discovered through looking the Detrola record player up on Amazon, for the specs. The company that makes these is Electrohome. Here is the website, which provides access to support for their products.
Posted on Apr 14, 2012
I have a califone 1430k record player, and the arm is loose. It looks like the spring must have come loose. It is still attached by wires, but nothing else. If I take it apart, do you think I could fi
The arm should have a pin through it that secures it to the bracket that is attached to the arm bearing. There should be a long spring that is used to adjust the tracking force and it is underneath the arm.
The arm can be taken off by taking the player apart, unsoldering the wires from the arm and unscrewing the nut on the turntable bearing.
Because the arm mounts to a soft rubber grommet it should feel a little loose.
Hope this helps.
Jan 16, 2014 | Califone International Audio Players &...
Ford taurus hazard lights and turn signals not working
remove bottom screws under the steering wheel remove bottom cover and then the top cover where the turn signal arm sticks out . then remove the connector attached to the multi function switch at the turn signal arm. spray real good with circit cleaner . then put connector back on. should then ,if not replace the turn signal arm which has the multi function switch attached .about 50 dollars on a 96 taurus at auto zone.
Apr 13, 2012 | 2002 Ford Taurus
The wires connecting the play stop & cue have come loose on my optimus LAB 1100. I need a diagram to show me where to hook them up PLEASE!!!
The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 24, 2011 | Audio Players & Recorders
Opening the PL-Z81 box after standing packaged for quite some time -I saw that the turntable had come apart and that there were four pieces - a silver dish (the turn table) --the rubber mat that sits on...
Ok! On the main part of the turntable should be a spindle, not the one in the middle! That if you put your finger on will turn. This is the motor. On the underside of the silver dish should be a flange. Place the belt round it and put the platter on the center spindle (the one in the middle). If the platter has a hole in it, grab the belt and pull it, while rotating the platter till you can see the motor spindle. Attach the belt to that. Put the rubber matt on and try it out.
The black piece is for 45's with big holes in them (jukebox ones).
PS if the platter hasn't a hole you will have to put the belt on the motor spindle first and then around the flange (try not to pull the belt to much).
Also some turntables pass the belt via a leaver that lifts the belt up and down for 45 and 33 speeds, others just change the motor speed.
Aug 23, 2010 | Audio Players & Recorders
Reattaching sprayer arm?
This is a backward (left hand) thread, when you put the spray arm back on to the nut turn the nut to the left.
If you need more information this link shows how to clean out the sump (which you do not necessarily need) but it also has a picture of how the lower spray arm pieces fit that might be helpful.
May 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Jvc ql-a5 service manual wanted, the arm it return to midlle of disk instead begining.
I had the same problem, you have to open the turntable, there's a rubber piece that pushes the arm to the arm rest. It becomes sticky with the years, and when this piece of gear goes back to the normal position, it takes the arm to the center with it. just clean the tiny piece of rubber or put a piece of paper on it.
Sep 24, 2009 | JVC Audio Players & Recorders
SL-BD22 Stops as you move in the tone arm
I am not particularly familiar with this model but if you have to have a disk on the turntable in order for it to run (a safety for stylus protection perhaps) why not just put on a disk and see? This feature would be a fairly complex one (photosensor perhaps) and I would not expect to see it on an inexpensive piece. Likely as not this has to do with a switch inside probably activated by a cam wheel (used in the raising of the arm at the end and returning the arm to rest) that is not set right. This cam or some link to it may have a problem which need to be addressed. All this I grant is speculation which would become clear if I saw the unit but unfortunately that is not an option. As to whether its a piece of junk, I wouldn't buy it unless I thought I could make it work. Paying any real amount of money to another to fix it makes little sense to me.
Jul 03, 2009 | Technics SL-BD22 Turntable
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Jan 25, 2009 | Crosley CR248 Turntable
Philco 841.205 TurnTable spring and plastic armature pulled off HELP
Well it turned out that that 45 degree plastic piece DID or WAS attached to the main post. It snapped off. I super glued it back on and to each side of that very flimzy broken plastic I cut two very small pieces of wood (using popsicle sticks) and super glued THOSE to either side of the broken armature piece. Once dried I re-attached the spring and it worksd like a charm.
Oct 10, 2007 | Philco 841205 Turntable
4,652 people viewed this question
