Question about Konica Minolta PagePro 1400W Laser Printer
Asking for file name before printing
When i press print ,the window pops up asking for file name.
    Sergeant:
  • 366 Answers
Check and remove setting: "Print on fiile" in printer properties windows
Posted on Feb 22, 2009
Cannot print PDF, pop up asks to print to file and enter an Output File Name
If you have a virtual printer (PDF printer like BullZip, PDFPrint, or something else) maybe it is your default printer and when you chose the option "print" you need to choose the the right printer (in your situation HP Officejet Pro L7780 )
Good luck.
Jul 13, 2012 | HP Officejet Pro L7780 All-In-One InkJet...
I have created a bi-fold bulletin for my church using Cosmi Print perfect Gold and I need to send the bulletin off to the printing company but they need it in a pdf format. Can I make this in a pfd format?
Yes you can. If the software to do this is already installed, when you sellect Print... a pop up menu will appear with a list of your printers init. Select the one that says pdf and it will ask you for a file name. This will then save your file as a PDF. If you do not have the PDF printer listed here is a fee option to download one.
http://www.primopdf.com/
this is an easy way to create a pdf for the print company.
Hope this helps
Apr 04, 2012 | Cosmi Corporation Print Perfect Gold...
My printer doesn't work as it should be beacause i tried to print a page, i pressed ok but it didn't come out
Hi Bianca!
What you should do is to clear the print spooler - the printer queue. If you're using windows, right click on my computer and then press in "Manage", in the opened window go to "Services and Applications" and then "Services". go down the alphabetical list in the right window pane until you come to the service with the name "Print Spooler". Right-click this entry, then select "stop". This will stop the service that holds your print queues. Leave this window open, press on start and then type "spool" in the search bar (or in the "Run" command line if it's windows xp) and press enter. In the opened window, go to a folder named "PRINTERS", and Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just
hit "delete"). Close the explorer window now that we have emptied the cleared spool files, and return to your Services window. we must re-start the Print spool service, and do so by right-clicking the Print Spool entry and selecting "Start" from the list. Close the services window and try printing again. It should work now. Good luck!
Jan 10, 2011 | Lexmark Z617 InkJet Photo Printer
Hello. my lexmark 2500 all-in-one won't print. when I select print, I get the page verifung the printer and how may copies i want but when I hit ok, nothing happens.
Hello! What you should do is to clear the print spooler - the printer queue. If you're using windows, right click on my computer and then press in "Manage", in the opened window go to "Services and Applications" and then "Services". go down the alphabetical list in the right window pane until you come to the service with the name "Print Spooler". Right-click this entry, then select "stop". This will stop the service that holds your print queues. Leave this window open, press on start and then type "spool" in the search bar (or in the "Run" command line if it's windows xp) and press enter. In the opened window, go to a folder named "PRINTERS", and Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just
Dec 23, 2010 | Lexmark X2500 All-In-One Printer
Since yesterday I am unable to print documents that open in Adobe format, although was able to do that before. Now when I click on "Print" button, the pop-up window tells me to Print to File and Output...
Instead of click the Print button go to File menu, then Print, and THEN select your printer.
It seems you don´t have your printer set as default.
Let me know if it worked before leaving negative feedback. So we can still try.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 15, 2010 | Office Equipment & Supplies
My canon mx330 printer ask me this questions when i hit the "print button" it pops up a window that asks"output file name"? I'm suppose to type something inthere?
Check that the printer shown in the print window is the MX330. It sounds like your default printer is set to be a virtual printer such as Microsoft XPS or Acrobat PDF. You need to set the MX330 as your default printer by going to your Printers and Faxes window, right-click on the MX330 printer and select "set as default" on the list there.
Oct 23, 2009 | Canon PIXMA MX330 Multifunction InkJet...
What is print to file? What is output file name?
It is windows way of storing a document for printing later.
It will save the job you want to print at another time but ask you for a file name so that you can give it a name you will remember.
It will do this if it is set as the DEFAULT printer.
To change that and provided you have a printer installed then go to CONTROL PANEL / printers and faxes / then right click on the printer you want as the default and on the box that opens will be that exact option, click it and you are done. it wont ask you those questions again.
If this information was useful please click below
Aug 19, 2009 | Konica Minolta magicolor 2550 EN Laser...
Its keeps asking for my output file name when i go to print.what is a output file name ?
Sounds like whatever your printing to is set for print to file or your default printer has changed.
Go into the control panel, select printers, select the printer that you want to use and press the right mouse buttons for properties.
Select the ports tab and make sure that the file box isn't checked and that the USB port is (or whatever port your printing with).
Press ok
Make sure that you printer is set for default printer.
Jun 10, 2008 | Office Equipment & Supplies
Printing e mail
When you click on the Print button located in File, a dialog will open asking to you to choose your printer. Make sure to select your printer (Lexmark E238) in the printer name field.
Let me know if it works.
Feb 06, 2008 | Lexmark E238 Laser Printer
Konica Minolta PagePro 1400W Laser Printer Logo
226 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
