Question about RCA RCR311B Remote Control
How can i get to the vidoe channel with this remote
I have a sanyo tv
  • 514 Answers
Go to the lowest channel for your TV then press channel down til it says "VID 1" or such then enter/ select! good luck!
Posted on Feb 22, 2009
Trying to connect Sanyo to infinity cable. Can only get 1 channel.
you may be trying to change the channel with the TV remote. The TV probably needs to remain on channel 3, then switch to the Cable remote (make sure its in Cable mode) to change channels.
Dec 14, 2017 | Sanyo Televison & Video
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
How do i get to video mode without original remote
you should have an input button. if so press the button until you get to the input that your dvr/vcr player is on. if you do not have a input button got to the menu button and you should be able to change the input thru the menu.
Jan 11, 2010 | Sanyo AVM-2759S 27" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Channel 3
most TV will allow manual entering of numbers on the remote.
if you have the remote try typing "03" thats Zero Three on the remote.
you might have it in video mode like vidoe one or s-video there different mode for a tv. check on the remote for source or TV/VIDEO button, to make sure the TV is in TV mode.
also on the TV itself there should be a menu button some TV have RESET option. look for that
or just goto the WEBSITE of the manufacture of the TV set im sure they have ONLINE manuals too.
Good Luck
Jun 14, 2008 | Curtis-Mathis CM19011 TV
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Televison & Video
Sanyo DS31350 31" TV problem
you need to buy the sanyo remote from www.sanyo.com
Dec 14, 2007 | Sanyo DS31590 31" TV
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
RCA RCR311B Remote Control Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
