My samsung 32" lcd hdtv will not turn on. The red light is on but it is not blinking. I have my tv hooked up to comcast cable and a dvd player which both come on but not the tv!!!
Hi, Does tv show No Red in all inputs like tv programs, dvd player etc? Let me know connection setup with tv and what is video source hooked in tv to diagnose problem. Unplug tv and video source (cable box, dvd player etc) from wall socket for minute to get them reset, replug back in and turn both units On and check. Thanks.
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
No HD channels on a DCT700, you have to have a HD capable box from comcast. Usually $8.95 a month for box rental. Don't know a lot about DVD players. If you get a comcast HD box, and have an HD TV, you should use an HDMI cable for best picture. Second choice is component cables. Those are the red, white and yellow or red, white yellow, blue and green cables.
It sounds like something is shorting out do to an incorrect connection. Make sure you are matching the correct colors if using composite (RCA) or component cables.If you are using composite than hook the yellow for video and red and white for left and right audio. For component cables use the red blue and green for video instead of yellow and use the red and white from the composite cable for left and right audio leaving the yellow unplugged. You should have the cables coming from the DVD players output going to the TV's input. Select the same input on the TV that you have plugged into. If you are using coax cable through the DVD player if it has a tuner than you will need to change the TV to channel 3 or 4 depending on what the DVD is switched to. After you are done with the DVD player be sure to turn the power off so the cable can work properly. I am guessing here since I don't have much info to work with so I hope this helped you.
Just make sure you hook up the wires to the correct plugs. They should be colr coded - red and white for audio and yellow for video. The sockets on the TV will have the same color code. If not, its just a matter of trying various combinations. If nothing works, then try using a different cable.
