Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
Akai LCT2701TD TV does not turn on, front LED Orange flashes What could it be the problem ?
  • Anonymous Feb 28, 2009
    Had tv for aprox. 2 years led light flashes and thats it no sound or picture
SOURCE: AKAI LCT2701td TV No Picture
its the power supply. cheap chinese slave labor! well i.ve been looking for a replacement power supply anyone have any ideas where to find one?
Posted on Jan 03, 2008
  • 395 Answers
SOURCE: AKAI PDP5006H Plasma tv
Have the SSB modual replaced. the problem is the talk back to the power supply shutting down the system. it may need prior authorization to order but best guess is SSB after that it 's the digital board. have a tech determine the ture problem. the best thing to do is call the akai for the nearest repair or go to the web sight. some of the akai products are made by Funia.
Posted on Jan 16, 2008
Twizted
  • 30 Answers
SOURCE: Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Posted on Jun 25, 2008
dsacco86
  • 1077 Answers
SOURCE: lct2701td akai brand, plugged in, flashing red
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, purchase a Service Manual over the internet at Nodevice.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
MY 4YEARS AKAI LCD TV IS BLINKING ORANGE LIGHT BUT
Read the info from the link below to troubleshoot the failure with your LCD. Try not for force the LCD to work because for the time being it might only need the capacitors listed in the link but if the lights is blinking red, then the failure is a bit more complex to repair.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
Feb 28, 2010 | Akai LCT2701TD Television
While watching the tv it stopped playing and a red
Are you still having trouble?Please let me know.Thank You very much!
Tyler
Feb 06, 2010 | Akai LCT2701TD Television
My Akai LCT2701TD will turn on to a blue screen but then turn off
<font size="4"> Did you fix this yet?Please let me know.Thank You very much!<br /> Tyler<br /></font>
Nov 30, 2009 | Akai LCT2701TD Television
Akai lct2701td, flat screen tv won't turn on.
Oh Dear. I had the same problem!! The Akai televisons are not well engineered-meaning that they tried to put too much in a little package. The problem is that the power supply is malfunctioning"supposedly". But I believe that the sad truth is that the whole motherboard is malfunctioning. I can suggest a few TEMPORARY solutions but they too are not guaranteed to work!
1. Bring the tv to a repair shop and tell them to check the power supply. If it is faulty -have it exchanged and it will work for <2 weeks.
2. Literally "bend" the television in multiple directions to find a sweet spot where the screen turns on.( wait for the diode tu tur green before doing this) this will slightly bend the motherboard in hopes of agitating it to turn the screen/bulbs on.
I am terribly sorry that you too have this ridiculous problem!!!!!! :-(
Good Luck!!! I am crossing my fingers for you!!
Jun 10, 2009 | Akai LCT2701TD Television
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 26, 2009 | Akai LCT2701TD Television
AKAI TV REPLACMENT REMOTE CONTROL
http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=E7501-060001
Feb 08, 2009 | Akai LCT2701TD Television
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
Your pwer supply module has problem. Check diode (Z3) and 2 surface mount resistors (R65A and R65B).
Good luck
Nov 25, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
81 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
