Question about Nintendo Wii Fit for Wii
Upper right sensor not working on my balance board. Did sensor check and all working but that one. What can I do?
  • 1 more comment
  • jnazario1797 Mar 11, 2009
    The board can't detect the weight and is says that you are fidgeting.
  • Anonymous Mar 29, 2009
    I called Nintendo service and am getting mine repaired under warranty (90 days)
  • Anonymous Apr 01, 2009
    exact same thing... I was playing today, doing the step workout. It started out fine, but then it started saying that I was missing every other step. I finished the workout and did the diagnostic and the top right sensor wasn't working properly. I read the manual, double checked that the carpet wasn't interfering and everything else. I was using the rechargable battery pack and it was actually plugged in, so the batteries weren't an issue.
    Sergeant:
  • 319 Answers
Is it being used on carpet? if so, do you have the carpet extensions on it?
if this isnt applicable, contact nintendo for warranty replacement.
Posted on Feb 27, 2009
Hi,I've a problem with my GE. The clock show "F1" code sometines and it "bip", but the oven work. What can I do?Thanks
Check the wires going to the oven sensor. The temperature is controlled by 2 things--the sensor(looks like a thin metal pencil sticking out from the upper rear wall of the oven on either the left or right side) and the main board. There is a thin wire harness(2 wires) from the sensor to the main board. A big problem with ovens is the connector that joins the sensor pig tail to the harness from the board. It can become oxidized, heat damaged, etc. breaking the connection. The sensor should have about 1100 ohms of electrical resistance at room temperature +/- 10%. If the sensor and wires check good, then you have a defective main board and it will have to be replaced.
Aug 25, 2015 | GE Ovens
I did a balance board check and the bottom left and the top right sensor are not working. What do I do
Unfortunately, the balance boards are prone to failure. Your choices are to contact Nintendo about repairs (they tend to charge a small fortune) or buy a new one. Repairing this yourself would be difficult because the parts are not easy to get a hold of unless you are a repair shop.
Mar 21, 2011 | Nintendo Wii Fit for Wii
Misfeed in copier error E200
Hi how are you this is jack my personal ID
(jack_pak@hotmail.com)
Paper transport jam
[E200] Upper drawer transport jam (not reaching the registration sensor)
Open the jam access cover. Is there paper in front of the registration sensor?
YES Remove the paper.
NO
Is the registration sensor working? (Perform the input check:
NO 1. Check if the connector of the registration sensor is disconnected.
2. Check if the connector CN345 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the harnesses are open-circuited.
4. Check if the conductor pattern on the LGC board is short- or open-circuited.
5. Replace the registration sensor.
6. Replace the LGC board.
YES
Are the upper transport clutches (high/low speed) working?
NO 1. Check if the connectors of the upper transport clutches (high/low speed) are
disconnected.
2. Check if the connector CN362 on the LGC board is disconnected.
5. Replace the upper transport clutches (high/low speed).
YES
1. Check the condition of the feed roller, separation roller and pickup roller of each paper source, and
replace them if they are worn out.
2. Check the transport roller. Replace it if it is worn out.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
New motor board and the belt pulses
It sounds like the unit speed sensor is out of adjustment or the connections is not secure when replaced the new board and last thing some units sometimes need a calibration to tell the upper console to synchronize with the lower board.
Apr 11, 2010 | New Balance Balance 1500 Treadmill
Im having trouble with my balance board keeps repeating step off and press a.after a lot off turning the board over and over if it doesstart it wont give proper weight
the board is most likely defective, I have seen several boards with this problem. I believe it is related to the defect in the right rear foot sensor. try using the board check test to see if it will show the defect and replace the board.
Mar 23, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
? L5 Landice 8700
Upper display lights up;treadbelt moves;speed will not increase;L5 error.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
Unplug 3 wire speed sensor connector from
relay board. Check for pushed pins or loose
wires.
Any found?
Unplug 12 wire upper harness connector
from relay board. Check for pushed pins or
loose wires. Specifically look at 8 (White)
and 12 (Green).
Any found?
Is speed control wiring OK?
Purple wire from V+ on pwm board to P3 on relay board.
Orange wire from P1 on pwm board to P1 on relay board.
Brown wire from P2 on pwm board to P2 on relay board.
P3 on pwm board has no connection.
Adjust speed sensor:
1.Use 1/2" wrench and loosen
the two lock nuts securing
sensor to it's bracket.
2. Adjust sensor gap to 1/16".
3. Tighten lock nuts.
Repair or replace speed
sensor / harness assembly.
Part# 71007
Repair or replace upper
harness. Part# 70251
Correct speed
control wiring.
Replace the speed sensor.
Part # 71007
Feb 05, 2010 | Exercise & Fitness
Balance board not working properly
Regrettably, this seems to be a very common problem. Please contact customer service at www.nintendo.com to see about getting repairs made to your Wii Fit Balance Board.
Mar 26, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Wii fit balance board 3 quadrants are green and 1 is red
This means that one of the 4 sensors is broken. You will need to contact Nintendo via their website to get it repaired.
Good luck, and sorry about that!
Feb 11, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
WII FIT Board only recognizes movement on one side
Try doing the balance board test to make sure all the sensors are working probably. Click on "User Settings" (the wrench) on the wii fit plaza page. From there your should click on the "wii balance board check." It will walk you through the process and check your sensors to make sure they are working.
Dec 25, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
662 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
