It is a Haier dorm size refrigerator. It has power, the motor is hot a while after plugging it in. Sounds like it's running properly, but it won't cool, even if the temperature knob is changed.
UNIT IS NOT COOLING ON 110AC 50HZ OR GAS,BUT COOLS NORMAL WITH GENERATOR ON AC POWER APPEARS FINE ,IAM THINKING ELEMENT MAY BE WEAK,HOWEVER WHY IS PROBLEM SAME ON GAS???? CAN ANYONE ADVISE I WOULD BE GREATFUL FOR ANY ADVICE. TA MUCH>>>>IMCG UNIT IS NOT COOLING ON 110AC 50HZ OR GAS,BUT COOLS NORMAL WITH GENERATOR ON AC POWER APPEARS FINE ,IAM THINKING ELEMENT MAY BE WEAK,HOWEVER WHY IS PROBLEM SAME ON GAS???? CAN ANYONE ADVISE I WOULD BE GREATFUL FOR ANY ADVICE. TA MUCH>>>>IMCG
You can't post conmments that contain an email address.
If the freezer is working properly but the refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can try to fix the issue:
Check the thermostat setting: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
Check the condenser coils: The condenser coils may be dirty or clogged, preventing the refrigerator from cooling properly. Clean the coils with a brush or vacuum.
Check the door seal: Make sure the door seal is tight and not damaged. If the seal is not tight, cold air will escape and the refrigerator will not cool properly.
Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the refrigerator not to cool.
Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. You may need to call a professional to check the compressor.
If you have tried all the above steps and the problem persists, it's best to contact the manufacturer or a professional for further assistance.
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
If your Haier refrigerator is running but not getting cold, there could be a few different issues causing the problem. Here are a few things you can check:
Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. It may need to be replaced by a professional.
Check the refrigerant level: If the refrigerant level is low, it can cause the cooling system to fail. This is a job that should be done by a professional with the right equipment and experience.
Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
It sounds like your Haier refrigerator is having an issue with the compressor and cooling system. Here are a few things you can check:
Check the compressor: Make sure the compressor is running and not too hot to the touch. If the compressor is not running or is hot, it may be faulty and will need to be replaced.
Check the compressor overload protector: The overload protector may have tripped, check to see if it is tripped and reset it if necessary.
Check the compressor's capacitors: They could be damaged and need replacing.
Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
If you are not familiar with any of these steps or if the problem persists after trying these solutions, it's best to contact the manufacturer or a professional for further assistance.
If your 18 cubic foot Haier refrigerator is not getting electricity to the bottom fan, there could be a few different issues causing the problem. Here are a few things you can check:
Check the power supply: Make sure the refrigerator is properly plugged in and that the outlet has power.
Check the fan: Make sure the fan is not blocked or damaged and that it can turn freely.
Check the fan motor: If the fan motor is not working properly, it could cause the fan not to turn on.
Check the control board: If the above steps do not resolve the problem, the control board may be faulty and will need to be replaced.
Check the wiring: Make sure all the wiring is properly connected and not loose.
Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too high, the fan will not turn on.
If your Haier 10.5 model 10TG31SW refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can check:
It sounds like your Haier deep freezer is having an issue with the compressor and cooling system. Here are a few things you can check:
Check the compressor's overload protector: The overload protector may have tripped, check to see if it is tripped and reset it if necessary.
Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the freezer not to freeze.
Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the freezer will not freeze properly.
Check the power supply: Make sure the freezer is properly plugged in and that the outlet has power.
Check the clicking sound: If the clicking sound is coming from the compressor, it could be the compressor's relay switch, which is responsible for turning the compressor on and off. This could be the issue and will need to be replaced.
Please note that if a compressor is a sealed unit and you're not able to charge it, it's best to contact the manufacturer or a professional for further assistance.
HI .THIS SOUNDS LIKE IS A PROBLEM WITH LACK OF REFRIGERANT.1-check if it makes a sound when u plug in 2-if yes then feel the condensing pipes behind the refrigerator.nearest to motor should be quite hot gradually cooling down through the con/unit.con/unit cold then more than likely short of ref.be weary u might have internal leakage.if hot (thin pipe)assuming its running it could be 1-thermostat 2-internalbloackage.3-motor.hope it helps.Ali
Is there ice frosted on the back wall? If so you have a defrost problem and you need to replace the thermostat, Defrost timer and heater. This ensures the problem is totally fixed. if you can nail down exactly which of these parts is the problem then just replace the problem.
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
