Question about Toshiba 27D46 27" TV
Bad circuit code coding for d145 circuit on tobshiba 27d46
Lost my remote control for a Toshiba TV model 27D46. need the remote code for universal remote control.
Use code search to find something that can handle some or all functions of your Toshiba TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Dec 30, 2016 | Toshiba Televison & Video
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
http://www.manualowl.com/m/Toshiba/27D46/Manual/33233
Jul 28, 2012 | Toshiba 27D46 27" TV
My d145 officejet prints document page crooked
your adf assy is out-of-alignmnt or feed'g rollers/sep-pad are filthy/bad. +possible that rollers in ppr-feed(lower unit) need cleaning also. good luck... auburncord@aol.com
Jun 14, 2009 | HP OfficeJet d145 InkJet Printer
Printing with my second hand hp officejet d145
You can clean it with maybe a little alcohol then go thru the motions of cleaning from the printer controls
Feb 26, 2009 | HP OfficeJet D145xi All-In-One InkJet...
I need the code for one for all urc-3021 for an apex tv
It is one of the four digit codes listed here 0748 0765 0767
Here is the product page,
http://www.oneforall-na.com/remote.php?type=URC%203021
Here is the Code page
http://www.oneforall-na.com/list_codes.php?db_value=expert4&remote_choice=URC%203021
And here is the Programming steps page
http://www.oneforall-na.com/set_up_remote.php
If this helps, please dont forget to rate it FIXIT!
Thanks,
Charles
Jan 08, 2009 | One For All URC-3021 Remote Control
Is converted box necessary for Toshiba 27D46 tv
The Toshiba 27D46 has a digital tuner, so you should be good to go when the switch to digital occurs.
Dec 18, 2008 | Toshiba 27D46 27" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Remote
Try codes 0156,and 0765.
Jan 26, 2008 | Directed 434MHZ Remote Control
Toshiba 27D46 27" TV Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
