Agitator in washer is making lots of noise
Need to get the agitator out to see what is under it
    Problem Solver:
  • 14 Answers
There is a racheting gear made of plastic under the agitater. if the tub is overloaded it will strip the gear.
Posted on Feb 22, 2009
My GE top loading washer is making a clunking noise during agitation. Everything else okay
The problem may be in your agitator. The spline may be worn out. It is located under the spindle. Are your clothes becoming clean. That noise might be the agitator not fully engaged.
Feb 06, 2013 | GE Washing Machines
My type 111 washing machine was making a lot of noise and seemed to be unbalanced. But it was not. The inside kept moving around and causing a lot of noise. Now it doesn't do anything else besides fill...
Yes it sounds like the drive block has broke or loosened up it keeps the basket centered up and provides the transfer of power in the spin cycle from the transmission to the basket..The drive block is located right under the agitator. their is a jam nut on top of the drive block that needs to be removed, then replace the drive block then reinstall the jam nut and tighten securely reinstall agitator Good Luck
Sep 17, 2010 | Kenmore 24032\24036 Top Load Washer
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
The agitator in my washer is not working and it is making a weird noise
If you have the model number (lift lid and model, serial # etc. are on the cabinet, you can go to the Sears parts site.!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
Enter your model number instead of the 110.26902691
Then look under the heading Agitator, basket and tub.
The problem may be the "agitator dogs" (4 plastic pieces that allow the top agitator spin one direction only.
Beyond that, the agitator connects to the main drive shaft (with one bolt) in the transmission.
If you're reasonably mechanically inclined, and the problem isn't the dogs, you can pull and open the transmission. In it are a number of gears, springs, cams etc.
A Whirlpool manual (posted on a number of sites) gives a diagram and operating flow for the washer showing how the transmission works.
We had a problem with a lot of noise on our Kenmore and traced it to a plastic cam and follower in the transmission that wasn't lifting a gear far enough above the main drive gear so that we were getting a lot of gear clashing noise.
Sep 08, 2009 | Kenmore Washing Machines
Whirlpool ultimate care II - agitator makes a horrible noise
You may have worn agitator dogs, causing the upper portion of the agitator (called the "auger") to slip. Or, you could have a loose agitator bolt. The following link explains how to replace the dogs (if necessary) and how to access the bolt:
If you need to replace the dogs, the part number is included. You can purchase them for about $5 at For a little more, you can purchase the entire agitator drive replacement kit. Look for it under the "Agitator" parts section. You can also reference the helpful exploded view diagrams the site offers for assistance.
NOTE: When tightening the agitator bolt make sure you do not overtighten. This may cause damage to the agitator, or restrict its movement. Tighten until snug.
This repair should take about 10-15 minutes and does not require special tools, a repairman, or a lot of money. If you still require assistance, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Making a lot noise when washing cyles
Hi, The most common noise in the wash cycle is the agitator not working properly. While the washer is going, raise the lid and notice if the top half of the agitator is working. If it is not moving, you will need to change the dog kit inside the agitator. The other noise I hear most is the coupler slipping on the shaft of the motor. If the coupler is bad, the washer will not spin the clothes dry either.
Please let me kow if this helps you or if I can assist you further.
Jul 15, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
